#26 |
Carby is always the _last_ thing you should touch when chasing running issues, tune ups etc.
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#27 |
Re: 1969 250 help
I was going to rebuild the carb after it is running good . I noticed the other day that one of the gaskets looked like it had gas on it .
I did the initial tuning like you said ran better but still not running good . I now I have to do the one mark at a time thing like you suggested |
#28 |
It's the little things that make the most difference .
Don't sweat fuel stains around the bowl gasket, that's normal . First : Remove and check the spark plugs , you personally have to gap them properly using a WIRE GAUGE to .035" . Use a test light on each and every plug wire to see if they're continuous ~ if the test light doesn't light, replace that wire . Points to no more than .016" or 33° dwell if you can find/borrow (Pawn shops, $10) a Dwell/Tach meter ~ setting the dwell with the plugs removed and rotor off whilst cranking the engine guarantees best dwell and hottest spark . Look across the ends of the plugs ~ the center electrode _MUST_ be squared off ! if it's even slightly rounded the engine will never run properly . This stuff is easy to do and teaches you as you do it .
#29 |
Re: Tune Up
thanks for that i will do all thr this sat or sun . nice and slow ill get it done
#30 |
Keep us posted .
#31 |
Re: 1969 250 help
will do and thank you for all your help
#32 |
Re: 1969 250 help
Ok plugs done dwell good wires good set at 12 btdc . Runs better getting a misfire once in a while .would it be worth at this point to go hei ?
#33 |
Re: 1969 250 help
#34 |
Re: 1969 250 help
I have a 66 with oil bath air cleaner and the truck had been sitting for probably 20 years. It would quite frequently spit just when starting under load and take a while to clear itself. With carb kit there was no difference but with HEI from a 78 Nova the problem went away completely. It must have had a weak coil or bad plug wire.
#35 |
RE : Electronic Ignitions ~
Yes, a thousand times yes . My '69 C/10's 250 i6 engine is in bad shape ~ it runs fine but fouls the spark plugs every 250 miles or so, adding the HEI setup from a '76/'77 Chevy Nova makes it run perfectly all the time . With HEI you open the spark plug gaps up to .060 and they'll fire no matter how much oil is getting past the rings or valve guides . Even the basic Pertronix " Ignitor" points replacement system will give you a noticeable boost in power , smoother idle , easier starting and improved fuel economy .
