Old 10-10-2016, 11:18 AM   #11
mcbassin
Still Learning
mcbassin's Avatar
Re: Knomadd '71 SWB C-10
Originally Posted by knomadd View Post
Hahaha, my thoughts exactly! Thanks guys!!
Well, I moved on from the wiring, figuring I'd have better luck sorting through it with the engine/trans out of the truck.
This weekend I started on fixing the firewall. Was pulling a dent I found when the stud pulled the sheet metal apart. Ground off the paint and bedliner/undercoating crap to find some pinholes. Cut it out and made a patch, which lead to blow outs. I hate thin sheet metal and rust!!!
I guess GM never meant for these panels to be flat, so the entire blower motor area is low, which is why the welds still show up. I didn't want to grind through any metal, so I'll have to try and work the steel as best I can. Thankfully I'll be making a panel to cover most of this anyway. Heck, it might have been easier to replace the full face of the firewall in this area, maybe even this section of the cowl too.
Nice work on the firewall repair and filler. Do you have a plan for the other openings? I know I made the mistake of cutting the whole section out and cutting a one piece filler plate. (HERE) Not a good idea in my opinion. On my next one, I will leave the rolled edges and just make two filler pieces. I had a ton of oil canning issues with the one piece. I've seen the ones made by porterbuilt, they should be better because it has a rolled edge.
I hate repairing the rust in this area. It can be a real pain to get rid of it all.
good luck!
