Old 10-10-2016, 12:05 PM   #9
Electricduane
Re: 89 Suburban: correct door jamb switches??
Originally Posted by BLE 'BURBAN View Post
This will indeed work in your door jamb. It is designed to self adjust to the proper length when you close the door.
If you look closely at the switch, you will see a sleeve that runs thru the nut. When you close the door the door will contact the button of the switch which will bottom out against the sleeve and will push the sleeve in until the door is completely closed.
Since it is a very tight fit inside the nut, once it's set it shouldn't move again.
See, I never would have known that, I thought it would just punch a hole in the side of my door. I will install and try it. Many thanks for the reply!
Electricduane is offline   Reply With Quote
courtesy light, door jamb switch
