Old 10-06-2016, 03:29 PM   #1
Porkey
Question Help please
I got a 1984 Chevy Silverado c/k 20 series 4x4 3 quarter ton pickup I just replace the gas tank on it brand new I hope everything back up to get around the block and next thing I know it dies off and acts like it's out of gas I put gas in it it would not start only time it starts when I prime the carburetor with gas I replace the fuel filter in the carburetor can't find the main line canister filter anybody out there please help me figure this problem out I need to take my butt back to work if my truck is down I can't go to work please
Porkey is offline   Reply With Quote
Old 10-06-2016, 03:56 PM   #2
Shugalou
Shugalou's Avatar
Re: Help please
Fuel pump not working? I've haven't overhauled this system so unfortunately I don't know all the potential hickups - choke working on carb? possible air lock?
May the force be with you
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 10-06-2016, 07:22 PM   #3
100%Chevy
Re: Help please
Could you have kinked a rubber line at the tank?
Mike.
100%Chevy is offline   Reply With Quote
Old 10-06-2016, 08:05 PM   #4
tucsonjwt
Re: Help please
Do you have the hoses routed correctly at the fuel sending unit? I would disconnect the fuel line coming out of the fuel pump and and have someone crank the engine to see if you have any fuel coming out of the pump.
tucsonjwt is offline   Reply With Quote
Old 10-06-2016, 10:05 PM   #5
cadillac_al
Re: Help please
Since you just replaced the tank there must be a problem with that. I would hook a longer 3/8 fuel hose to the metal line leading to the fuel pump inlet and try to suck some gas through that line. If you use clear hose you may not have to drink any. It sounds like you may have gotten a hose kinked or something.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-07-2016, 12:18 AM   #6
barry1982
Re: Help please
I would also bet you have a kinked rubber hose the sending unit. I had the exact thing happen to me one time.
barry1982 is offline   Reply With Quote
Old 10-13-2016, 09:16 AM   #7
Porkey
Smile Re: Help please
Yeah I figured out what the problem was the fuel lines were hooked up backwards thank you guys for all the good information
