Old 10-04-2016, 01:30 PM   #901
TJ's Chevy
TJ's Chevy's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Nice job.
Old 10-04-2016, 07:40 PM   #902
62stepside longbox
62stepside longbox's Avatar
Originally Posted by RKS0069 View Post
Very nice! You are doing an amazing job.
I bought my first truck ('72 c10 swb) when I was 16 years old. drove it for a few years and then started striping it down but with minimal tools and money I did not get past that point, so now I'm 38 and still have the truck in pieces.
I bought a '62 GMC roughly twelve years ago and drove it most of that time, now I have it ripped down as well, yes two trucks in pieces. Every time I see your posts I kick myself in the butt for not working on my truck more. I'm not letting that happen to the GMC! Thanks for all the motivation, looking forward to seeing you complete your truck.
Thanks man, hopefully I can get you motivated enough to get your truck done. I know for me the most important part is keeping myself motivated so I actually keep the progress going and get the truck finished. Good luck with yours
Originally Posted by TJ's Chevy View Post
Nice job.
Thanks buddy
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 10-08-2016, 10:14 PM   #903
62stepside longbox
Yesterday was the start of a 4 day long weekend, and I already got a good bit done. I removed the heater assembly from the firewall and took it all apart, cleaned and sanded and then got some practice with the paint gun and sprayed it gloss black. It turned out pretty good.
Old 10-08-2016, 10:26 PM   #904
62stepside longbox
I also removed the old steering box and started to mock up the 78 box, plus removed the cowl panel and started to get the firewall cleaned. Today I went out and bought a different rear end that's from a 71-72. I was going to use the rear end from the 78 but I didn't think it would work to well since it has 3.07 gears and the 261 doesn't have much power. The new rear end has 3.73 gears which should work nicely with the t5 and six. I am going to take the backing plates and brakes from the 78 12 bolt and use them on the 71-72 12 bolt so I can have the wider brake pads and larger diameter drums (the 78 had a towing package with heavy duty brakes)
Old 10-12-2016, 10:22 PM   #905
62stepside longbox
Mocked up the ps box on the frame with some spacers and clamps, this is exactly how it'll sit. Oh and some bad news, that rear end I just bought from my buddy turned out to be another 3.07! Just my luck, He was almost positive that it was a 3.73, but it's all good as he has a 3.73 gear set sitting around so I'm going to pull out the 3.73's and trade him gears
Old 10-13-2016, 02:43 PM   #906
scoot_mcgrute
Looking good, my friend!
Seeing your heater assembly all cleaned up really makes me want to do the same to mine. Looks like there are bolts at the cowl and then some coming from inside the cab to take it off?
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 10-13-2016, 02:58 PM   #907
Deer_hunter_088
Deer_hunter_088's Avatar
Yup, definitely watching this one, maybe itl give me hope in finishing my '69 before i graduate!
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 10-13-2016, 07:31 PM   #908
62stepside longbox
Thanks Scott, and yes to remove it there are bolts coming from the firewall and some little ones coming from the cowl area.
Just keep on cranking away at it, I don't know if mine will be fully painted before I graduate but at least it will be a nice daily driver. I've still got more than a year left
Old 10-13-2016, 07:33 PM   #909
Deer_hunter_088
Yup mine just needed a starter and a grill but it snowballed big time
1998 S10ZR2
Old 10-13-2016, 07:38 PM   #910
62stepside longbox
Yeah trust me I know about snowballing, if I wanted I could have replaced the clutch slave and a few brake parts and then been a daily driver, but no I felt the need to start modifying everything and adding more and more onto the list. Now it's turned into a full resto-mod
Old 10-13-2016, 07:41 PM   #911
Deer_hunter_088
Ikr! Itts like nah if I'm doing it I'm doing this this this this and this. Like i was checking wires because i had a gauge light fault. now my dash is all apart. i was seeing if my carb was good. Ended up pulling the intake. just because
1998 S10ZR2
Old 10-13-2016, 08:27 PM   #912
62stepside longbox
Yep, it's all fueled by the saying "while I'm doing this I might as well do that"
Old 10-13-2016, 08:39 PM   #913
62stepside longbox
I don't think I've shown this old school gun rack I bought a while back, it'll be mounted in front of the back window just like all the trucks used to have years ago. I'll be using it for my guns while hunting, but mostly things such as fishing rods plus using it as a hook for say jackets etc.
Old 10-13-2016, 08:57 PM   #914
TJ's Chevy
TJ's Chevy's Avatar
Perfect example of "While I am doing this I may as well....." is my 305 v6. What started as a basic reseal and repaint turned into a almost full rebuild. lol
Old 10-13-2016, 09:36 PM   #915
66ChevyMax
66ChevyMax's Avatar
I haven't seen a 3 gun rack before, cool!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 10-13-2016, 11:30 PM   #916
62stepside longbox
Yep lol, there's no such thing as a small project
Yep it's cool for sure, I bought it out of Oklahoma
Old 10-17-2016, 08:28 PM   #917
62stepside longbox
On the weekend I got a second coat of gloss black on the heater and then I buffed and polished it today with some very fine buffing compound. Turned out really nice.
Old 10-17-2016, 09:02 PM   #918
TJ's Chevy
TJ's Chevy's Avatar
You can do mine to while your at it. lol!
Old 10-17-2016, 09:43 PM   #919
Advanced Design
Advanced Design's Avatar
Hey 62, read all through your build and really appreciate your skill and focus. Been quietly tagging along and look forward to the rest of the journey.
Advanced Design is offline   Reply With Quote
Old 10-17-2016, 10:41 PM   #920
62stepside longbox
Haha sure, if you can pay for my plane ticket down there lol
Thanks for the complements Doug, I try to engineer and build my own stuff rather than buying it so I can continue to learn and improve at being a better builder, plus I'm cheap , keep on following and I'll try to keep all you guys entertained.
So lots going on at the time with the truck, making tons of progress, I have the rear axle at the auto shop at my school and just today I pulled the axle shafts out, removed the backing plates, removed the carrier and then removed the ring gear, I should have the pinion out in the next couple days and be able to trade gears. I'm also taking a huge advantage of the metal shop at my school with all the great equipment, tomorrow I'll be working on making an adapter for the power steering box and possibly building new axle perches. Also just yesterday I cut my frame open and removed the internal bracing that interferes with the ps box bolts, plus started sanding the firewall to get it ready for paint. I'll do an update in a day or two with pictures of all of this.
Old 10-19-2016, 01:30 AM   #921
AJCK87
Heater box is looking nice! Are you going to change out any of the seals? Looking forward to seeing some pictures of the rear end coming together. Keep up the good work!
AJCK87 is offline   Reply With Quote
Old 10-19-2016, 11:01 AM   #922
62stepside longbox
Thanks Anthony, the seals were actually in really good shape so I just cleaned them up and put them back in, I should have an update on the rear end later Today
Old 10-19-2016, 10:13 PM   #923
62stepside longbox
Over the past few days I've been working hard on the rear end, I got the backing plates off, pulled the axle shafts out, measured backlash, pulled the carrier, removed the ring gear, measured pinion depth, measured pinion bearing preload, removed pinion yoke and pulled out the pinion. The axle housing is now completely empty, I'm going to replace seals and likely the carrier bearings. Over the weekend I'm going to trade the 3.07 ring and pinion for the 3.73. Then before I put it all back together I'm going to clean it up, move the trailing arm mounting pads, put on the later backing plates with larger brakes and then paint it
Old 10-19-2016, 10:13 PM   #924
62stepside longbox
The housing
Old 10-19-2016, 10:16 PM   #925
62stepside longbox
I also made some progress yesterday on the power steering conversion, I cut out this section of the frame to reveal the internal bracing behind the steering box, the problem with this is that one of the bolt holes for the new ps box lined up right on the bracing
