Old 03-20-2004, 03:57 PM   #1
ocbaud
Garage Queen Material
carb. accessories?
if i were to get this carb:
http://www.jegs.com/cgi-bin/ncommerc...26&prmenbr=361
what all else am i gonna need to get it hooked up correctly?
what else would i need to get for it so i could tune it and make sure its running the best it can
ocbaud is offline   Reply With Quote
Old 03-20-2004, 06:22 PM   #2
TIMSPEED
TIMSPEED's Avatar
Re: carb. accessories?
I would definately but the secondary spring package, so you can tweak your secondaries. Other than that, you MIGHT need to swap jets, but you can pick those up for like $5 at a local speed shop.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-20-2004, 09:58 PM   #3
ocbaud
what about throttle brackets and things like that?
i'm not wanting to reuse any of my old ones.
Old 03-20-2004, 10:48 PM   #4
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
I would get Jegs Part# 720-9678 , 865-2418 & 720-1558.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 03-21-2004, 03:25 AM   #5
ocbaud
http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...77&prmenbr=361
would any of those work? what else would i need for my kickdown cable?
Old 03-21-2004, 03:45 AM   #6
Destructo
If your running a 700r4 you will want to get the 700r4 bracket for holleys. You can get them at advance auto, they should have a big book with all the parts in it, don't remember the part number but its basically a 700r4 bracket for the throttle and TV Cables. Bolts to the base of the carb through the back right carb stud/bolt.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 03-21-2004, 09:20 AM   #7
ocbaud
th350
Old 03-21-2004, 10:28 AM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
a quadrajet or a Edelbrock to swap out for when you want to actually drive it without working on it....
Gchemist, I think, has the part number for the throttle bracket assembly.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-21-2004, 12:53 PM   #9
toytruck
toytruck's Avatar
I never run a kick down on a HiPo motor. Thats what the shifter is for.
Old 03-21-2004, 04:35 PM   #10
1FaastC10
1FaastC10's Avatar
from expeirience, i know that manual shifting an auto trans is a bad idea.
http://store.summitracing.com/partde...rt=SUM%2DG1414 would be the part you need for a Holley carb. i would strongly suggest you rethink your choice of carbs. look at how often Tim posts about working on his... i cant count the number of "i've fixed my stumble" posts i've seen out of him. they're just not good for a daily driver. spend a few extra bucks and get a 1904, you'll be much happier.
1FaastC10 is offline   Reply With Quote
Old 03-21-2004, 04:39 PM   #11
TIMSPEED
TIMSPEED's Avatar
The only reason, is because I have a busted-ass Smog Holley. If I had a plane jane Holley 750, I would like it MUCH better.
See Them Here
Old 03-21-2004, 09:48 PM   #12
Captkaos
Captkaos's Avatar
Wanna bet?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-21-2004, 10:03 PM   #13
ocbaud
well, i was thinking about getting one of the jet peformance qjets, but i would have to get an adapter plate for it also, which means lots more money. if i do anything, i'll buy a holley street avenger. would a 670 or 770 be better?
Old 03-22-2004, 01:36 AM   #14
ocbaud
so if i were to get all this stuff, i would be good to go?:
http://www.jegs.com/cgi-bin/ncommerc...28&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...40&prmenbr=361 510-34-160
http://www.jegs.com/cgi-bin/ncommerc...31&prmenbr=361 (just because i want it and its cheap)
http://www.jegs.com/cgi-bin/ncommerc...37&prmenbr=361
Old 03-22-2004, 12:29 PM   #15
toytruck
toytruck's Avatar
Yup. Don't forget the fual pressure gauge.
Old 03-22-2004, 02:46 PM   #16
ocbaud
okay, cause i get paid wendsday and will possibly order it then
