Old 10-16-2016, 02:33 PM   #1
dmjlambert
dmjlambert's Avatar
Question Doohickey fell out of ignition cylinder lock
Can you help me temp fix my ignition cylinder lock? I had sudden failure of the lock, I couldn't turn the key without doing some serious wiggling. So I removed it to have a look. I suppose I need a new cylinder, but I can't get one today. The cylinder has a little bar that moves up and down depending on whether the key is in it, and I suppose that's what makes it lock. The bar has 2 doohickeys, one on each end. You can see in this picture it appears 1 has fallen out. What holds that in place? Is it just pressed in, or do I need to do something to make it fit and stay?
Old 10-16-2016, 02:53 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Doohickey fell out of ignition cylinder lock
That's a tumbler from the lock. I'm turning the summins light for lock doc....he'll be able to tell you if it's fixable or not.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-16-2016, 03:53 PM   #3
Coach
Coach's Avatar
Ignition lock tumbler and I don't believe it is repairable.
1967 Chevy C10 Stepside SWB - 350/700r4
Coach is offline   Reply With Quote
Old 10-16-2016, 03:55 PM   #4
kwmech
Yeah, just pick up a new key assy. It's when the thing-a-ma jigs falls out, that's when you have to worry.
Old 10-16-2016, 10:42 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I have fixed them. The spring retainer is just crimped in. You can try to put it back in place and re-stake it, but you will need to turn the spring upright first. It is laying on it's side.
If that doesn't work and you need to drive the truck you can remove the spring retainer from the other side, remove the bar, and re-install the lock cylinder,(it will no longer lock) or just just operate the switch with a screwdriver.
LockDoc
Leon
Old 10-16-2016, 11:35 PM   #6
dmjlambert
dmjlambert's Avatar
Thanks. I turned that spring upright and put the retainer back and staked it. It seems to be holding. You're the guy to talk to about buying new cylinders for the doors and ignition with matching keys, right?
Old 10-17-2016, 01:56 PM   #7
LockDoc
LockDoc's Avatar
Good deal on the repair. You might want to put a little JB weld on the ends of the retainer too.
Yes, I have a few of the OEM sets.
LockDoc
Leon
ignition switch, lock cylinder
