Closed Thread
Old 10-14-2016, 09:29 PM   #4501
matthamby
Re: What did you do to your truck today? Chapter II
Got them installed this afternoon!
The small things do make a big difference
matthamby is offline
Old 10-14-2016, 09:46 PM   #4502
74baggedbug
Buddy told me I could have it, they are sending the cab to the scrap yard
74baggedbug is offline
Old 10-15-2016, 07:01 PM   #4503
66clow
66clow's Avatar
Rattle canned some more fautina. Few more panels to complete bodywork. Sanded rust off the vent windows. Got all the bolts in my reclaimed wood bed.
66clow is offline
Old 10-15-2016, 09:00 PM   #4504
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Originally Posted by Dan Myshrall View Post
Thanks, Gone... Sitting inside is like stepping into a time machine.
You did real good with your purchase, most of the time the wood floors are shot in these trucks.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 10-16-2016, 01:03 PM   #4505
IronmanC10
I posted on page 178. Today I hugged my truck because it is officially mine! I also removed the box, let the work begin.
IronmanC10 is offline
Old 10-16-2016, 07:58 PM   #4506
In The Ten Ring
Picked up the driver's side outer fender from the painter. The other fender still needs a bit of work though. Soon, she should be ready for reassembly!
In The Ten Ring is offline
Old 10-16-2016, 09:13 PM   #4507
OregonNed
OregonNed's Avatar
I switched to clear parking light lenses
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 10-16-2016, 10:24 PM   #4508
custom10nut
custom10nut's Avatar
Yesterday I replaced my broken vent window. Today I refurbished my door panels. They will need replacing in the future but they look pretty ok for now. Also treated them both with rust inhibitor paint. I didn't get to the dash replacement this weekend, and I have to go out of town tomorrow, so that'll have to wait till next weekend.
custom10nut is online now
Old 10-17-2016, 09:35 AM   #4509
matthamby
This has given me some inspiration, I have thought of using rustoleum brand rattle cans, about how many did it take for you to cover your truck?
Old 10-17-2016, 10:06 AM   #4510
66clow
66clow's Avatar
Thanks, it really isn't that bad. I still have bodywork on the white of the cab to do and the right fender and door. Rustoleum covers really good. I used satin. Most panels I give about 3 coats and a coat of black underneath over the body work. I'll have about $100 or less in spray paint at around $3 a can. I scuffed it down with a 3m red scuff pad after I sprayed it. I tried using some polishing compound to give it a little sheen. Before photos below. I don't have the money and time to disassemble to do a real paint job right now so this works.
66clow is offline
Old 10-17-2016, 10:19 AM   #4511
matthamby
I was thinking about an orbital sander with a scotch brite pad on it first, then sanding as needed to remove runs. I don't have time to remove panels either, but, I'm going to try it anyway! I'm thinking of tackling the bed first - will have to order some hardware for replacing the ones I'm sure I'll have to grind away!
Old 10-17-2016, 04:07 PM   #4512
suburban99
suburban99's Avatar
Added some rally's and 35's
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline
Old 10-17-2016, 04:42 PM   #4513
Dad's72
Dad's72's Avatar
I started my build I guess you could say. I got down under my truck and removed the driveshaft, hanger, the exhaust, radiator and supports and got it ready to remove the motor and transmission. I will be degreasing it all underneath and cleaning it up for the new motor which I will bolt onto the transmission after I clean it up and add new seals, filter, and gasket. I am also dropping off the radiator to be flushed and pressure tested. I was surprised to see it full and still bright green after all these years sitting. Since 96 or a few years before.
Dad's72 is offline
Old 10-17-2016, 04:54 PM   #4514
In The Ten Ring
Your truck came with a motor? How rare is that model? Mine came with an engine.
Just messing with you, technically these are "engines" as "motors" are electric, but most everyone wants to use the wrong term, even saying "crate motor" instead of "crate engine."
All I did was inquire about a cluster, buy some cluster parts, and figure out a new use for my truck (when running). I just now bought a boat that I plan to haul in my truck.
Old 10-18-2016, 07:38 AM   #4515
matthamby
OK, so went to a festival Saturday and on the way back saw this on the highway - to each his own, I didn't care for what he had done, but it is definitely a head turner. I had my sister take the pictures.
Old 10-18-2016, 11:21 AM   #4516
Boog
laying low
Boog's Avatar
Whoa son. He's got the sun visor, wide whites, contintental kit, mag wheels, bikes, coke trailer. You won't find another one like it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 10-18-2016, 12:29 PM   #4517
matthamby
one day his wife probably said get rid of all of that junk laying around the house"
he said "that's all good stuff, I'm not throwing it away, it's for my project"
She said "it's junk, throw it away!"
he just had to prove her wrong!
Old 10-18-2016, 12:30 PM   #4518
matthamby
double post
Old 10-18-2016, 11:28 PM   #4519
VWNate1
VWNate1's Avatar
Talking Snark alert !
This just goes to prove that in matters of taste, every one else is WRONG .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-19-2016, 05:28 PM   #4520
RodnRudy
RodnRudy's Avatar
Got busy and welded up the old mirror holes today in prep for my new sport mirrors. It was a quicky job, weld, grind, spot prime, and rattle can some color and we're good to go.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 10-19-2016, 05:30 PM   #4521
RodnRudy
RodnRudy's Avatar
Upper holes in the window frame.
Phil
RodnRudy is offline
Old 10-19-2016, 06:49 PM   #4522
BugzC10
BugzC10's Avatar
Finished up installing Jeep fan conversion.....test it in the morning.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 10-19-2016, 08:50 PM   #4523
67-C10
67-C10's Avatar
Tonight I worked on my DBW pedal and was able to mount the 71-72 pad on the 03 Silverado assembly. Still need to make a bracket for it in the cab.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now.....
Needed: paint and lots of it. and i'm sure lots more misc. parts.
Project 67 short step Build Thread
01 Sierra Crew 6.0
2015 Ford F150 Work gave me truck i really wouldn't buy a ford.
67-C10 is offline
Old 10-21-2016, 11:42 AM   #4524
BugzC10
BugzC10's Avatar
Finished installing and setting lash (E-O,I-C) comp Cam Ultra Roller Rocker and New Magnum push rods...test drive later
BugzC10 is offline
Old 10-21-2016, 12:18 PM   #4525
re1
re1's Avatar
Well now you have to show us more pictures.
1972 Chevy C10 Custom Deluxe Highlander
1972 Chevy C10 Custom Deluxe Medium Green
re1 is offline
Closed Thread
