![]() Join Date: Feb 2016
Shorten longbed stepside with single cut?
I've seen how others have shortened their fleetsides by removing 12 from the front and 8 from the rear. I am about to pull the trigger by shortening my long bed stepside bed by just removing 20 inches from the middle and just redrilling the 9 holes for fenders. Is there any reason why this wouldn't work?
![]() Last edited by KenAdams; 10-17-2016 at 12:02 PM. |
Re: Shorten longbed stepside with single cut?
There is a guy here in Yucca valley I believe he only shortened the front of the bed by around 10/12 inches (he was shorting the frame also) made a 7 + foot bed LOOKS GREAT ......Personally I do not see any reason taking it all out of the middle would not work for a TRUE short bed
I posted Wrong
Born and proudly residing in a Red State ! |
1961 crewcab
seems like it would be more work to fill all the old fender holes, also harder to get the new ones in exactly the right spot.
the way I see it you are going to have 1 vertical cut to weld and grind regardless. for the second 1/2 which would be more work: 1 vertical cut and weld/grind /fill, or measure and drill 9 holes, then weld /grind/fill 9 holes.. also with the center cut method, the ridges in the bed behind the fender will end up all wrong.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Another problem I see is that the bottom of the bedside has the cutout, if you cut it in the middle it will shorten the cutout area
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#6 | |
https://youtu.be/O9zy08qsahk?list=PL...VzshsQUYn8POdz This should help you out with it. |
60-66 Nut
I would recommend making a template for the fender holes, prior to cutting the bedsides.
#8 | ||
Thanks Captain.... You might have saved me on that one. I'll measure everything out and CAD up the dimensions if anyone else wants them. |
It's a wise thing to not do just straight cuts. I would recemmond checking the video and making the cuts like they do in their. It will be stronger than just a straight cut vertical
Currently living with Cancer. Trying to build up a 1963 Chevy. |
Yep, I actually z cut the frame and tacked it together a while back, still need to finish welding it up, but that's a different day. All I really have to do now is tackle shortening the bed. I've seen countless other people shorten their longbed fleetsides, but have never seen anyone do a longbed stepside. My thinking behind the single seam in the stepside is I am going to leave the truck with its patina anyways so the only thing that would standout is a seam. If I just have a single seam in the bed I can hide most of it behind the fender.
Just an observation and thought.
Rather than cutting down your long step bed. Have you thought of offering it up for trade? I know there are several here that are actually looking for a long step bed and they are getting harder and harder to find. Someone may be willing to buy one of those new repro short beds and trade or even trade a good OE short bed for the long. I'm just thinking it would be a shame to cut up a long step when people are looking for them. Just my .02 cents worth.
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue. http://67-72chevytrucks.com/vboard/s...d.php?t=523009 |
#12 | |
