Old 10-17-2016, 02:56 PM   #1
Mikemelton
73-86 control arm swap ride height
I've searched and couldn't find an answer. I'm putting '86 control arms and spindles on a '65 C10 frame. Question is will it change the ride height from factory?
Mikemelton is offline   Reply With Quote
Old 10-17-2016, 04:22 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 73-86 control arm swap ride height
If you don't change the springs, no it will not change. The track width will increase by about 3/4" wider per side.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-17-2016, 04:38 PM   #3
Mikemelton
Ok how much difference is there in the springs? I have 2" drop springs on the '86 frame
Old 10-17-2016, 11:38 PM   #4
Captainfab
60-66 Nut
The springs are interchangeable.
Old 10-18-2016, 10:42 AM   #5
chevy_mike
chevy_mike's Avatar
As Capt. said, springs will interchange. Keep in mind that you don't know how much springs have sagged in the '65 so even with swapping the 2" drop springs, you might not get 2" drop from the current height. If they sagged 1" and you put in 2" drop springs, your net drop will only be 1" because the truck was already 1" lower than factory.
