Old 10-20-2016, 12:41 PM   #1
dirish
dirish's Avatar
Is the crate 260hp enough ?
I have read and read but..... who has the 260hp in a 4x4 blazer. All stock. Plan on keeping manifolds insted of headers.
opinions on a daily driver crate 350, looking at the 260hp. But..... is it enough? I don't need to race people I just want reliability and power to go the speed limit.
330hp is nice but don't want to go electric fuel pump.
Thank you in advance.
dirish is offline   Reply With Quote
Old 10-20-2016, 01:28 PM   #2
orange72blazer
orange72blazer's Avatar
Re: Is the crate 260hp enough ?
I have one in my Blazer but I pulled the heads & replaced them with some rebuilt vortec heads & replaced the cam with the Comp Cams XE268H. I did this when the engine was new so I have no idea how it ran stock but it runs awesome set up like I have it.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 10-20-2016, 01:43 PM   #3
72gmguy
72gmguy's Avatar
I'm sure the 260 horse motor has more power than any stock motor that ever came in a first gen blazer. They rated hp differently back then. Plus everything I've read recently about those motors is that they respond well to mods and are very durable. I just read an article not too long ago and I think they put a turbo charger one with low boost and it survived a bunch of dyno runs unscathed.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 10-20-2016, 01:49 PM   #4
dirish
dirish's Avatar
Mine has a week original 350. I'm thinking anything would be better. Is the l31 vortex motor a simple drop in? I need a new intake, anything else?
Thanks!!
Old 10-20-2016, 02:17 PM   #5
starterman99
starterman99's Avatar
The L31 does not have fuel pump mounted on block so you would need electric fuel pump. also has one piece rear main oil seal so you would have to replace flywheel.
1950 5 window
starterman99 is offline   Reply With Quote
Old 10-20-2016, 05:32 PM   #6
hemi43
hemi43's Avatar
The 5.3 swaps that everyone is doing are only rated at just 300HP, and thats more than enough power. I guess it all depends on what you plan on doing with the truck. If you put an overdrive transmission behind that 260HP engine and 4.10 gears you'll be more than happy, IMHO.
hemi43 is offline   Reply With Quote
Old 10-20-2016, 07:42 PM   #7
bigdogz
Its plenty of power. I put it in mine and love it... I have a 4" lift and run 35s. I have headers on mine. If I had it to do over I would put the same motor in it.
bigdogz is offline   Reply With Quote
Old 10-20-2016, 08:32 PM   #8
dirish
dirish's Avatar
Thanks, is that a th350? I believe I'm gonna order jegs kit .
Old 10-20-2016, 09:42 PM   #9
bigdogz
Thats where mine came from. I bought the kit with carb.,distributor,intake. Little over 2k.
Old 10-21-2016, 03:39 PM   #10
dirish
dirish's Avatar
Just found this, looks like the bet for my needs.
Karlperformanceparts.com part number 10067353K3
Complete, any thoughts. I'm no mechanic so I'm trying to keep it simple.
Old 10-21-2016, 05:38 PM   #11
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
That is just he GM crate engine 10067353 with a gasket set.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 10-21-2016, 06:00 PM   #12
dirish
dirish's Avatar
K3 kit comes carb to pan, water pump, starter.
crate 260hp
