Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-20-2016, 01:47 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Dim Turn signals
Originally Posted by Zack19919853 View Post
Ok so blinkers work now after soldering a wire to the brass on the tail light housing!! Whoop whoop!! Lol but there's something odd the left side blinker is blinking on a different filament? Why is that? Also the blink quicker as well!! I'm so excited!!
Remember I asked you about the wires to the lights, and the possibility that they might be reversed,and were they quick disconnect, or hard wired. If they are both the same number bulb, and was the brightness the same?
If they are both the same number bulb then I would swap the two and see if the filaments that light now are the same ones after the swap. The flasher has a heating element inside it that separates after the blinkers light for a second due to the heat of the resistance of the bulb, and the resistance of the element. This makes the light go out until the element cools and then it reconnects. This is what makes the blinker light flash.
The higher the resistance the faster the light blinks.
Oh and another problem my signal indicators in the dash both blink as if the hazards are on when I turn the left or right blinker on...
There is a good possibility that the dash is not grounded well and the flasher indicator lights and some other items might be poorly grounded. They will usually use the path of least resistance to ground, which could be another light which would make both lights flash. Make sure that it's not the hazard unit in the steering wheel which would make all the lights flash.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
electrical issues, electrical problems, electrical short
