Old 10-05-2016, 10:36 PM   #1
gmachinz
If anyone needs a builder in the central Iowa area....
....in the spring I'm looking to expand on my harness business by offering to take on a few large scale builds....I'll be finishing my 86 K10 first but here's a couple recent builds of mine....keep in mind I'm as big into Gbodies as I am squarebodies!
gmachinz is offline   Reply With Quote
Old 10-05-2016, 10:38 PM   #2
gmachinz
Re: If anyone needs a builder in the central Iowa area....
Did I mention I like building Gbodies...? In particular Monte Carlos...? Here's a quick 4-pic presentation of this 86 SS build....
pic #1...
Old 10-05-2016, 10:39 PM   #3
gmachinz
pic #2....
Old 10-05-2016, 10:40 PM   #4
gmachinz
pic #3...
Old 10-05-2016, 10:44 PM   #5
gmachinz
Pic #4....all done....BC/CC PPG Onyx Black, 5 coats of clear, buffed out to 3000g and a Phoenix Graphics decal kit on it. Car originally had 56K on it and the reason I took the project was because the body shop in Illinois had it in prison for over 6 months without even touching it. The story goes the guys wife drove it to work one nice Friday and a deer decided to jump across the lane in front of her. Needless to say, the front end was destroyed-narrowly avoided a bent frame. He brought it to me here in Iowa from Illinois along with a parts car and a lot of NOS parts-most of which he bought from me originally.
Old 10-07-2016, 12:06 AM   #6
68shortwide
68shortwide's Avatar
I assume those are the ROH Impala SS look alike wheels? I'm guessing you didn't convert the car to 5x5 just for a set of wheels.
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 10-07-2016, 04:59 AM   #7
gmachinz
Yep they are! Actually, ROH made a small initial run for GM and then GM outsourced them. So these are "knock-off GM" but made by the the original supplier lol.
As for the bolt pattern, I converted the car to using B-body spindles w/Hotchkis uppers a-arms, and I went with the 5 on 5 Impala SS rotors because they were thicker than using 1LE Camaro ones. I then had the stock rear axles re-drilled for 5 on 5 and had new, longer 1/2 racing studs pressed in at all four corners. I did several other suspension upgrades but with the wheels I did NOT want to run any kind of wheel adapter-this way the wheels bolt right up like stock.
Old 10-07-2016, 05:06 AM   #8
gmachinz
At the time, OE Wheel Distributors out of Canada sold these wheels for $650/set delivered vs me paying $550 each for "GM" wheels new from the dealer. The only difference is with these wheels you get a black adhesive center piece instead of an Impala center and obviously there's no GM part number on these rims-but they are built by the same company that was supposed to build them for the SS until GM pulled the rug out from under them-which pissed off ROH Wheels-and GM didn't own the rights to the design-ROH did. I've compared the GM wheel to the ROH wheel when Infirst got them and the ROH "GM knock-off" is much nicer-the machine polish surface is nicer than the GM wheel on the inner section-GM went with a slightly dull finish-prolly just different enough that ROH couldn't sue.
Old 10-21-2016, 10:33 PM   #9
Tynee
I miss this truck.
Tynee's Avatar
My dad had an '86 SS with T-tops when I was in HS. I really liked that car. Would like to have another some day with a modern drive train in it. That car snuck around corners. It was long and sleek, and comfortable. Nice work on that one.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
