Re: Help w/ RPO on E/C Sequence Sheet
Wow, thanks guys, this is a lot of great info. A cab/chassis swap would make a lot of sense...the frame has been sprayed with an undercoating, and there's no overspray Ive seen anywhere on the body, which doesn't fit the type of work the truck has seen from the previous owners...a bit too clean, if you catch my drift. Either way, it's been a great project so far, and it's definitely kept me on my toes. Thanks again everyone.
Dustin 1978 GMC K25 350/4 speed |
Check that the vin on the build sheet matches you truck...if not your seat may have come from another truck...with its build sheet.
