Help with LED installation into parking lights
So, I have read almost every post dealing with LEDs on here. I bought some 1156 leds for my front park/signal lights. Installed them along with a EL12 flasher, and of course, they would flash when the signal light was triggered. But, they would not flash with parking lights turned on. I even tried putting a load resistor in and still the same thing. What am I missing here???
#2 | |
Old member
Re: Help with LED installation into parking lights
![]() The bulbs you are talking about are not in my opinion worth the money are the trouble they will cause in the truck. I tried everything several years ago and nothing worked. I gave up and bought panel LED for the truck. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Feb 2004
My guess would be this. The wires are reverse for the functions you want. They probably have a resistor in them so they have a bright side and a dime side. Since it is backwards of your system you get a blink on the dim side when the park light is off, but when you turn the park light on you have full voltage making them constant bright. Therefore you see no blink. Now the only way to know for a fact is flip your wires around but that probably requires cutting them and in my .02 not worth the trouble caus they are not very good or bright any how. The dim side should be constant on with park. Then when you hit turn you get full voltage and the light gets brighter causing a noticeable blink.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Hmm, yeah, I really don't want to switch wires around. I could have sworn that someone had made this work somehow! Thanks for the responses! Keep them coming!!!!
Well the thing is gm did not wire every truck exactly the same. I get this with tail light installs. Some work great. Some have to swap their wires. I guess they figured it did not matter since a bulb will work the same no matter how you turn it. Leds are not like that. One wire is park one is turn and it gets ground from the housing. If you have 3 wires and alligator clips you could at least check with out cutting....
OK, thanks Rob! I will try that tomorrow!!
if its an 1156 bulb the pins are the same height you can just flip the bulb in the socket but aren't 1156 only 1 filament bulbs anyway they wouldn't have a bright and dim
Update: I tried to flip the wires around lid Rob suggested and still the same error. It was like I did nothing. I am pretty confused on this one!!!
Wow. I'm stumped. Can't think of what would cause it.not to work.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Old member
Good luck with it.
As I stated in my first post I never could get them to work like they advertised. Just a big head ache and time consuming. I also swapped wires and fixed wires and changed fittings. You name it I did it! Keep at it though and maybe you will discover what the right combo is to get them working. ![]()
I have finally got this to work!!!!! So, I ordered a flasher with dual polarity and the ground lead wire. Installed it today and I also installed an led into the side marker on that side. That's all it took!!!
#14 | |
Its a Truck Thing......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#15 |
![]() Join Date: Oct 2016
So how do they look in comparison to the original? Do you see a major difference and what is the total out of pocket on your project?
I was looking at replacing mine with the LEDs not just the bulbs. Do you have any before and after pics? |
#16 |
I have only done one side. I will do a comparison in a day or so.
#17 |
You know I could still be persuaded to trade trucks when you get them lights right.....
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
#18 |
Sure, here is an amazon link from where I bought it. Only thing is that once the blinker switch goes back to the neutral position, I still hear the blinker click a couple more times. The lights don't blink, but it makes the sound
EF32RLNP Electronic LED Compatible Turn Signal Flasher Relay, DOT APPROVED, POLARITY INDEPENDENT, 2 Prongs + Ground Wire, 12 Volts https://www.amazon.com/EF32RLNP-Elec.../dp/B01GIU9M0Y |
#19 |
#20 | |
Thanks,
Smitty Quote:
#21 |
Here is difference between regular bulbs and leds...
![]() Here is both leds installed... ![]() This is with the parking lights turned on and the signal light blinking Here it is with only the signal light flashing and parking lights turned off Only thing that I wished is that when the parking lights turned on and the signal light on as well, that the light "flashes" more. |
