Bench Seat Tilt?
Hey all,
My seat seems to be upholstered in such a way that the back does not tilt forward. I am assuming it was able to tilt forward from the factory in order to access the fuel tank. Correct? |
One foot in front of the other
![]() Join Date: Aug 2008
Re: Bench Seat Tilt?
Correct- it should look something like this.
Can you loosen the upholstery and then reattach so it allows movement?
Never Ending Projects
Early bench seats had this function. Later ones did not. Are you sure this is the original seat? I think '69 was the change over year IIRC.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
