Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-17-2016, 11:09 AM   #126
70stroker
70stroker's Avatar
Re: 70 GMC 4wd version
Originally Posted by cmabolt View Post
I may have a new one I can send you. Let me check. I'll get send you a pm later today.
Sounds awesome look forward to hearingfrom you.
70stroker is offline   Reply With Quote
Old 04-17-2016, 02:54 PM   #127
El Dorado Jim
Originally Posted by 70stroker View Post
http://www.ebay.com/itm/H5001-H5006-...NSqPFw&vxp=mtr
I wanted to use the truck and not be afraid of scratchimg a nice paint job, and i wsnted all the trim which i dont have and csnt afford. So I figure over time ill buy trim piece by piece and when i have it i will do a proper paint job.
your truck looks great, but what color did you paint it, it just looks like you have been sanding on it in the pics
El Dorado Jim is offline   Reply With Quote
Old 04-18-2016, 02:44 PM   #128
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Your truck is looking great. I like your idea of the work truck paint job. Yours will sure looks better with time than the primer I put on my 95 Ford Crew cab.
Ryan
1969 Chevy milk truck
Old 04-18-2016, 09:57 PM   #129
70stroker
70stroker's Avatar
Thanks man, some wont like it and that is fine, im enjoying this truck morenthis waynthen i ever did when it was shiny.
Trailer got a winch
[img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/A1CC8B38-9160-4D6B-8F14-EE50160EBC2B_zpsrt3tf5n3.jpg[/img]
[img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/57880446-93EF-46C5-AB5C-779255B5A304_zpsl960nkob.jpg[/img]
[img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/D7AB1883-6359-42A7-8CD9-022ED1F28FFB_zpsoigx82qn.jpg[/img]
[img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/Trailer/F1E77910-38B5-4BE6-B624-29062B4B920F_zpsu9mz0gqv.jpg[/img]
Old 04-18-2016, 10:00 PM   #130
70stroker
70stroker's Avatar
[QUOTE=70stroker;7565398]Thanks man, some wont like it and that is fine, im enjoying this truck morenthis waynthen i ever did when it was shiny.
Trailer got a winch
Old 10-15-2016, 09:54 PM   #131
El Dorado Jim
anything new done to the truck?
Old 10-16-2016, 11:00 PM   #132
70stroker
70stroker's Avatar
ya I took a few months off from it, then I put on a fitech fuel injection kit on it and drove it for about 3 months. Never really was to happy with it, so I sold the fuel injection to a buddy of mine and sold the big block and the 700r4 about 2 weeks ago.
Old 10-22-2016, 05:15 PM   #133
70stroker
70stroker's Avatar
Today I got the donor truck stripped down and ready to pull the motor and the transmission tomorrow, Also go the dirty dingo motor mounts installed. They are great quality and I would recommended them to anyone, however I was a little disappointed that I had to modify my relatively new ss brakes lines because the mounts don't have a provision to allow them to pass thru.
heres the donor truck I bought for 900.00 bucks
Dirty dingo mounts
Old 10-22-2016, 05:55 PM   #134
GSP7
GSP7's Avatar
weird looking mount/cross member
Is that a LS 5.3 liter motor?
What did you do with the orange paint job, sand it off. or what? ? ?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
No Snivelers
"No Lowballers, I know what I got"
GSP7 is offline   Reply With Quote
Old 10-22-2016, 06:11 PM   #135
70stroker
70stroker's Avatar
yes it is a 5.3 ls. I am going to be running the 5.3 with 4l60e out of the donor truck also along with my 208 transfer case, just have to figure out how to make the vss work as it is the transfer case out of the donor truck.
The mount/crossmember is a dirty dingo unit, I went with it because I really liked how the bottom part is removable incase a oil pan is ever needed to be removed while the engine is in the vehicle.
Old 10-22-2016, 10:10 PM   #136
72MARIO
72MARIO's Avatar
following the ls swap
I have a longhorn chassis that's getting converted to 4x4 this winter and was looking at the dirty dingo crossmember as its getting a 6.0/4l80
I used the mounts the dirty dingo mounts in our suburban that got 6.0/4l80. There mounts fit perfectly. LS swap is best thing I ever did to that truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-24-2016, 09:14 PM   #137
Dieselwrencher
Do you plan to flip the tcase to be RH drop and then just modify the oil pick up in the tcase?
Ryan
Old 10-26-2016, 08:28 PM   #138
70stroker
70stroker's Avatar
No my 208 is out of a 85 k5 blazer so it is a passenger side drop. I just need to figure out how to make it read a vss. From what little research I have done I believe I can take the 241? Apart out of the donor truck and rob the vss and the reluctor out of it and the just drill and tap my tail shaft on my 208.
Old 01-22-2017, 08:53 PM   #139
70stroker
70stroker's Avatar
Been busy with holidays and house projects but did manage today to get the engine stabbed.
Old 01-23-2017, 01:04 AM   #140
mud.man.rj
mud.man.rj's Avatar
That's a start, good for you.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-30-2017, 07:42 PM   #141
70stroker
70stroker's Avatar
Got the intake bolted on and transmission installed
Also figured out what I am doing for a trans mount (will post pics tomorrow).
Got the exhaust manifolds mounted off of a 98 Pontiac firebird formula. Scored them from my neighbor for 25 bucks.
Old 09-14-2017, 09:40 PM   #142
70stroker
70stroker's Avatar
got the 5.3 running fighting vss and trans not shifting kinda at my wits end now.
thinking im gonna do a adavance adapters part number 50-0405e, anyone have any experience?
on a side note what photo site are people using now that photobucket did their change????
Old 02-18-2021, 06:07 PM   #143
70stroker
70stroker's Avatar
Trying to get pics to work, any advice on getting them to rotate?
Old 02-18-2021, 10:27 PM   #144
mongocanfly
mongocanfly's Avatar
ive found if they turn out sideways..i rotate them to correct...usually they will be right..if not then i then crop the sides off and they will usually stay right side up
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-19-2021, 10:24 AM   #145
70stroker
70stroker's Avatar
lets try this
Old 02-19-2021, 10:24 AM   #146
70stroker
70stroker's Avatar
Hey man that worked great, Thank you!
Old 02-19-2021, 11:00 AM   #147
57taskforce
All about them K’s
57taskforce's Avatar
Looking awesome!
Tyler
Old 02-19-2021, 06:16 PM   #148
70stroker
70stroker's Avatar
Originally Posted by 57taskforce View Post
Looking awesome!
Thank you man, really appreciate it!
Old 02-20-2021, 06:29 AM   #149
Richard
Nice truck. Reminds me of my youth and first 72. Growing up in in the snow. Good work on the mods.
Richard
Old 02-20-2021, 12:08 PM   #150
57taskforce
All about them K’s
Is that still 4” and 35 12.5s?
Tyler
