C10 Club Tennessee
Inline Power Steering Bracket Diagram
I'm installing a 250 in my truck and also adding power steering to it. Does anyone have a diagram of the power steering setup on an inline motor. This is what I got but can't figure out how it bolts on.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Re: Inline Power Steering Bracket Diagram
interested as well I have a 250 with power steering and would like to get that part up and working
Pictures that should help some.
http://67-72chevytrucks.com/vboard/s...82&postcount=1
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
This is the bracket shown without a pump. You should have to remove the top alternator bracket you have on your engine now and replace it with the one you got with the new pump
-Cody |
C10 Club Tennessee
Thanks Cody!
Notice in the link from SSTim, the two damper pulley grooves line up with the water pump pulley grooves like yours.
The GMCguy picture has a damper with wide space between grooves and the outside damper groove lines up with the inside pump groove. A lot of variables to contend with, but I think all use a double Alt pulley.
'67 GMC 2500, 292, 4spd, AC |
C10 Club Tennessee
![]() Join Date: Oct 2015
I just installed PS on my 250. It's hard to see your smaller bracket, but it should bolt on top of the head between the two front head bolts where there is a hole with no bolt and also bolt to one of the bolts on the top side of the water pump. It will sit over the top of the exhaust manifold and right in front of the intake.
Moderator
![]() Join Date: May 2007
Are you sure those are the correct brackets for a non-integrated head? They might be from a later model six cylinder.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
The Older Generation
Flipped GMC.guy's picture. A lot of difference between that bracket and yours.... LockDoc
![]() Join Date: Jun 2005
Those brackets are for an integrated head 250 I believe.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
![]() Join Date: Feb 2002
Here's what I bought off a board member, about 20 years ago. He thought they were for a 292 -- since they looked "different" -- but they are for a 250 anyway.
Wonder if I could Make them fit. This particular exhaust is the heavy duty manifold with 3 studs not 2 and cooling fins. Fins interfere with bracket. Might fit w/headers, ya know? Too late for a refund now.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-27-2016 at 10:47 PM. |
I have a complete integrated 250 I'll take a pic tomorrow. Maybe we can compare. I know the upper bracket worked when I pieced it together years ago
-Cody |
#14 | |
