09-23-2016, 10:39 PM | #251 |
Re: Plus Five
Check out 3m paint defender..http://www.ebay.com/itm/NEW-3M-Paint...591860&vxp=mtr
09-24-2016, 10:16 AM | #252 |
Re: Plus Five
That sounds interesting...
it says removable, does it peel off later if you want to reapply it?
53 Chevy Pickup |
10-01-2016, 02:33 PM | #253 |
Re: Plus Five
started putting the box back on the truck
53 Chevy Pickup |
10-01-2016, 02:37 PM | #254 |
Re: Plus Five
I made these brackets for the rear tail lights earlier.
also installed the tailgate...
53 Chevy Pickup |
10-01-2016, 02:43 PM | #255 |
Re: Plus Five
some more,
53 Chevy Pickup |
10-01-2016, 11:11 PM | #256 |
Man of Mini-Talents
Re: Plus Five
Cool job on the light hardware!
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
10-03-2016, 08:41 PM | #257 |
Re: Plus Five
put the rear bumper brackets and covers on, and installed the license plate holder and side skirts.
also installed the license plate lights.
53 Chevy Pickup |
10-03-2016, 08:43 PM | #258 |
Re: Plus Five
some more....
53 Chevy Pickup |
10-03-2016, 09:37 PM | #259 |
Re: Plus Five
truck is looking great
1955 2nd on 86 chassis Daily driver |
10-04-2016, 09:57 AM | #260 |
Re: Plus Five
WOW! alot of really nice mods and very nice work. Going to beautiful when done.
1950 3100 5 window |
10-04-2016, 07:26 PM | #261 |
Re: Plus Five
Thanks everyone,
I'll be putting the rest of the box and fenders on soon, then I should be able to start running wiring again.
53 Chevy Pickup |
10-05-2016, 07:10 PM | #262 |
Re: Plus Five
installed the rear bumpers and backup lights
53 Chevy Pickup |
10-05-2016, 07:13 PM | #263 |
Re: Plus Five
backup lights
53 Chevy Pickup |
10-08-2016, 07:37 PM | #264 |
Re: Plus Five
put the rear fenders and running boards on today!
53 Chevy Pickup |
10-21-2016, 02:10 PM | #265 |
Re: Plus Five
I started installing the dash components so i can move ahead on the wiring.
I made this LED turn signal and high beam indicator some time ago, so I took the PWM dimmer apart, extended the wires, and installed them.
53 Chevy Pickup |
10-22-2016, 02:54 AM | #266 |
Re: Plus Five
Donandal
I'm in awe about your modifications and execution they're fandamtastic. I need a few details on photo's 2-4, what they are and how they're to be used. Thanks in advance Keep on keepin on NC
Been there, wrecked that |
10-22-2016, 06:27 AM | #267 |
Re: Plus Five
Thanks.
Photos 2 and 4 are pictures of a LED dimmer i bought, took apart, and lengthened the wiring to use for dimming the LED's I'm using for turn signal, high beam, and brake indicators. A typical headlight dimmer won't work to dim these LED's, so I used a pulse width modulator style I bought off EBAY for about $3.00. I'm using the rheostat to dim all four LED's simultaneously, thru their common ground wires. The dimmer knob will go just to the right of the steering wheel. The rest will be hidden under the dash. The LED's are just too bright for night time driving for my taste without dimming them.
53 Chevy Pickup |
10-22-2016, 06:30 AM | #268 |
Re: Plus Five
Picture three shows both an original one, and the one I extended.
I bought two just in case...
53 Chevy Pickup Last edited by donandal; 10-22-2016 at 06:31 AM. Reason: wrong picture |
10-22-2016, 02:54 PM | #269 |
Re: Plus Five
I installed the LED dimmer and the dash board extensions, A/C
louvers,and A/C controls.
53 Chevy Pickup |
10-28-2016, 08:03 PM | #270 |
Re: Plus Five
Not much to report.
I've been wiring up the Air conditioning and the headlight harnesses. While I was planning the wiring for the gauges, I realized I didn't remember which opening is for the speedometer and which one is for the gauges. I see pictures with the speedo on left, and pictures with it on the right. Any thoughts?
53 Chevy Pickup |
10-28-2016, 10:02 PM | #271 |
Re: Plus Five
I have them both ways and I like the speedo on the right, my eye goes to it easier
10-28-2016, 10:40 PM | #272 |
Re: Plus Five
10-29-2016, 11:28 AM | #273 |
Man of Mini-Talents
Re: Plus Five
I agree - the neat thing about custom stuff is locating things where you like them.
10-29-2016, 04:35 PM | #274 |
Re: Plus Five
That does help...
do you suppose the speedo was on the right because the steering column was slightly offset to the right from the factory? I centered mine when I put in the newer style column.
53 Chevy Pickup |
10-29-2016, 06:45 PM | #275 |
Re: Plus Five
Others will certainly be of more help than me 'cause I'm still just compiling datas/info on AD trucks and preferably panels and suburban as I plan on buying one to make a restorod with it. I only happened to have a PDF on 1953 ADs. Should you need it, just drop me a line in private with your e-mail address so I can send it to you.
JSavoie |
