Re: 5.3 with sm465 4 speed?
And what VSS model are you using as well?
I'm actually not using a VSS at this time, but if I was keeping the VSS I'd likely use this setup from Jags That Run.
http://jagsthatrun.com/Pages/Parts_S...ctor-Diff.html There are other solutions as well that would work, I believe some folks use a 8000 pulse inline sender that connects to the speedometer cable. |
#3 | |
What manifolds/herders are y'all using with the z bar linkage and sm465? I've got a c20 and about to put a 5.3 in it and want to use the factory linkage.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
I used a 98 Camaro manifold on the drivers side.
And it worked with the z bar?
