The Blazer King
Steering shaft
Anyone know the spline sizes into the box or into the column or length? I would like to get a custom shaft made since I can't find an aftermarket one.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
The Blazer King
Oh, This is for a 4x4 as well.
SKINNY TIRES RULE!
Do you have cross over? If not, you should consider it before getting the sterring shaft made, especiall with the big meats you got on that thing.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
The Blazer King
No Crossover and don't intend to. It drives very, very straight already and really doen't have bump steer at all. My stock shaft is on it's last leg though. I have contacted Borgeson Corp and they need those measurements to make a custom shaft. They are very good strength and quality.
Anyone know of a company that sells shafts that will fit? I don't wanna take my daily driver apart to make measurements.
Take it to Bob's machine shop over the bridge in Ruskin.
The Blazer King
Anyone got A parts truck laying around for measurements?
i have a 72 4x4 k 20 . what exact measure ments do you need?
69k5 |
The Blazer King
Length from box to column where it bolts up. Spline count on each side where it bolts in.
ill see what i can do tonight and let you know tommorrow.
Currently Blazerless
You might give Flaming River a try.
http://www.flaming-river.com/enter.htm
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#11 | |
69k5 ![]() |
Thier is a guy over at CK5.com that sells them for $75 I think If you go to the salvage yard you can get one out of a van and cut the center section down the vans use 2 ujoints like the flaing river joints and a vibraion dampner My joint with the dampner for my truck came from a van and Im using a flaiming river at the coulume and I only have abought $85 in the hole thing would have had alot less if I would have known abought the van thing.
Earl 68 2500 4x4 GMC Burb |
Cut out the middle section [-------------]
Drill out thr area where the shaft is 3/4" and put in a chunck of 3/4" chrome rod [=======] BLING BLING Very trick and you lose the Collapsable junk. Done it on my 2wd, very easy to do.. ![]()
72 blazer, 71 2wd short bed, 67 nova Too many damn toys!! |
i have the stock shaft from a 4x4 if u need one (cheap)
E-mail: earnhardt221@aol.com |
