Closed Thread
Old 11-01-2016, 02:52 PM   #4576
BugzC10
BugzC10's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by 67ChevyRedneck View Post
I put the caps/rings back on the wheels. Did a quicky spray can respray on the top so it looked decent again (fixed rust from back window when it was pulled/replaced). Added the CST badges and after I took them off 10 years ago, I put the C10 fender badges back on, although I don't like the factory spot, I moved them a bit
Putting the caps and rings back on made a huge difference...really like the look!
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 11-01-2016, 10:42 PM   #4577
jdalexa84
On Sunday I built a relay harness for my headlights that plugs into the original harness to activate the relays.
It hooks up to the power junction block and the harness has relay plugs that are mountable (haven't mounted them yet). So as for today I got to try it out since this was the first day I have driven my truck in the dark. Man what a difference.
jdalexa84 is offline
Old 11-01-2016, 11:56 PM   #4578
cornerstone
cornerstone's Avatar
Tonight I stitched up the rear passenger bedside in the slightly modified fashion of board member "65standard". I decided to bring my light openings along instead of asking him to borrow his presses that he so kindly offered to loan out to members. I really don't like the paint color on my truck so I'm not too concerned about saving it.
I really appreciate 65standards thread, he gave me the inspiration to give it a shot since I can't really afford new short bedsides at the moment👍🏼
cornerstone is offline
Old 11-02-2016, 02:32 PM   #4579
el_fantasma
el_fantasma's Avatar
Gaylord (r) bed cover. Getting painted next week
72 White Cheyenne, The Ghost
el_fantasma is offline
Old 11-02-2016, 07:58 PM   #4580
Bocephus69
Since it was such a nice November day, I took ol goldy locks to town to pick up my new toy that just showed up. I'm officially ready for winter now! Almost 50 years separate their build dates, and the sled's MSRP is more than quadruple of the C10.
69 C10 fleetside long bed - 6.0/4l80E in progress
Bocephus69 is offline
Old 11-02-2016, 10:34 PM   #4581
66clow
66clow's Avatar
My 69 orig came with reflectors , I wired up the side marker lamps.
66clow is offline
Old 11-05-2016, 11:52 PM   #4582
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Cleaned remaining parts from the column tear down and removed the brakes down to the booster bracket.
The rear brake line to the back of the combination proportioning valve was on real tight. Discovered you need to support the valve and its bracket with a big crescent wrench, when tightening/loosening that brake line. Bent the bracket, but I was able to bend it back. Lesson learned.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 11-06-2016, 02:21 AM   #4583
LongBox
Installed cigarette lighter in place of the "lighter delete plug"; installed rubber bumpers for glove box door so it opens when you push the button, and replaced the original all black lights and wiper knobs with ones with the stainless trim, so that they match the radio and the new lighter.
Tomorrow, if all goes well, I'm going to install the little metal plate that covers the small hole in the firewall on the right of the steering column. Mine came with tape covering the hole, and it looks like factory, as there are no holes for the plate attachment sheet metal screws, indicating that there never was a plate there. Since the tape was falling off, this will seal the cab interior from the engine bay noise.
Don't worry though, cause if I ever want to, I can return it to the way it rolled out of the factory.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline
Old 11-06-2016, 02:22 AM   #4584
LongBox
Tomorrow, if all goes well, I'm going to install the little metal plate that covers the small oval hole in the firewall on the right of the steering column. Mine came with tape covering the hole, and it looks like factory, as there are no holes for the plate attachment sheet metal screws, indicating that there never was a plate there. Since the tape was falling off, this will seal the cab interior from the engine bay noise.
Rick
LongBox is offline
Old 11-06-2016, 07:23 PM   #4585
TXTruck
Put some Packard 56 series 3 contact connectors on new LED side markers for the 72 C20. Just need to wire the rear markers to act as turn indicators now.
'72 C20 Custom Camper - SB350/TH350, Daily Driver
TXTruck is offline
Old 11-06-2016, 10:13 PM   #4586
67chevy1
67chevy1's Avatar
Size:  60.2 KB Took the engine back out of the frame after getting the break in runs done so I can take it to the dyno shop and see how my engine build went.
67chevy1 is offline
Old 11-06-2016, 10:22 PM   #4587
74baggedbug
Waiting on quickfuel technology to send back my carb.. putting around on this small carb sucks lol
74baggedbug is offline
Old 11-06-2016, 11:22 PM   #4588
Zeroman
Zeroman's Avatar
Talking Re: What did you do to your truck today? Chapter II
"LeRoy" got his grill on........
Zeroman is offline
Old 11-07-2016, 01:47 AM   #4589
VWNate1
VWNate1's Avatar
Question Re: What did you do to your truck today? Chapter II
Where did you get that beautiful grille please ? .
I bought a " GM HERITAGE " grille that was worse than my old slightly dented original one ~ no way could it be made to fit .
I'd love a nice one just like yours .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 11-07-2016, 11:24 AM   #4590
Zeroman
Zeroman's Avatar
I got it local here in Houston at Outback Truck Parts. Paul and Tracy are great folks to deal with.
For something like this I prefer to purchase local so I can "put my hands on it" and make sure it is a quality part. Bought the inner grill as well.
We had one of our larger swap meets this weekend and some of the replacement grills I saw were pretty bad...over spray on the paint and some with small dents and scratches.
Hope you find a good one.
Zeroman is offline
Old 11-07-2016, 11:48 AM   #4591
74baggedbug
I stopped in at outback Friday after I left the Conroe swapmeet.. yea I noticed also some of the replacent grills at the swapmeet weren't something I'd wanna receive in a box..
Old 11-07-2016, 11:55 AM   #4592
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
I just tried ther web site, it's all screwed up .
http://www.outbacktruckparts.com/default.aspx
They're in Spring, Texas now having just moved I guess .
-Nate
Geezer
VWNate1 is offline
Old 11-07-2016, 12:19 PM   #4593
Zeroman
Zeroman's Avatar
I'd call them direct tomorrow, they are closed today.
Zeroman is offline
Old 11-07-2016, 02:03 PM   #4594
BugzC10
BugzC10's Avatar
Added some more bling...chrome master cylinder
BugzC10 is offline
Old 11-07-2016, 02:22 PM   #4595
DarkFlounder
Got my eBay door hinges disassembled and ready for new pins/bushings. Only took the shop press, a lot of hammering, grinding the head off one of the pins, and a fair amount of cussing. But they're disassembled (almost, got a few roll pins to drill out) and ready for a proper cleaning, repainting, and new pins/bushings.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 11-07-2016, 03:16 PM   #4596
thedudeabides86
Active Member
thedudeabides86's Avatar
Greetings fellow North Dakotan! I'm originally from Grand Forks, living down in Albertville, MN as my wife's family is from down here.
I took a few loads of leaves over to the leaf pile last night. We dropped a new to me, used 350 in this and I'm still ironing out all the issues with it. Ran pretty well, considering I need a little carb fine tuning......
The Dude abides.
thedudeabides86 is offline
Old 11-08-2016, 12:24 AM   #4597
ekgguy
ekgguy's Avatar
Outback Truck Parts just when through a change of ownership. The new owners are trying to get a handle on the inventory, then they are going to work on the website.
Give them a call, they are excellent to deal with and really nice folks.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline
Old 11-08-2016, 01:49 AM   #4598
In The Ten Ring
I spoke with Wes from Classic Heartbeat and he gave me some major tips about reassembling my front end.
In The Ten Ring is offline
Old 11-08-2016, 09:49 AM   #4599
matthamby
And????????
It's sort of maniacal of you to tell us you have information, then not share it!
matthamby is offline
Old 11-08-2016, 02:39 PM   #4600
mud.man.rj
mud.man.rj's Avatar
Secrets hey, sure.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Closed Thread
