11-01-2016, 01:34 PM | #1 |
Neutral Safety Switch
I have a 64 C10 with 3-speed manual. Transmission is a heavy duty Muncie 3-speed from a 69 Pontiac. Hurst Shifter. Does anyone know of a neutral safety switch that is easily adapted to these trucks? If so, I assume it would function with the clutch linkage somehow?
11-01-2016, 02:31 PM | #2 |
Re: Neutral Safety Switch
just get a clutch switch from a later model and make a bracket to fit
11-01-2016, 11:57 PM | #3 |
60-66 Nut
I would look at a switch from a square body truck. I believe the neutral safety switch started in around '76?
11-02-2016, 02:35 AM | #4 |
http://www.ebay.com/itm/Clutch-Pedal...NXpexA&vxp=mtr
also look at post #12 here http://67-72chevytrucks.com/vboard/s...d.php?t=712185 I dont know if the contacts in that switch will hold up on start circuit Last edited by jtrichard; 11-02-2016 at 02:54 AM. |
