Old 09-12-2016, 12:36 AM   #1
Electricduane
89 Burb overhead console bracket removal ??
Hi, I have some rust under the console bracket (antenna mount hole leaked a bit apparently) . . It would be nice to be able to remove it, clean the rust, and put it back on.
Any advice? I don't see any easy way, and maybe no way, to remove those weird rivets so that I could reinstall the bracket. Maybe a nutsert? There's definitely not room to stick a nut behind the locations where the rivets currently are.
Thanks for any/all advice.
Electricduane is offline   Reply With Quote
Old 09-12-2016, 12:26 PM   #2
Electricduane
Re: 89 Burb overhead console bracket removal ??
Noone? Some further research suggests the plastic rivets might be common on japanese cards, and can be popped out with a door panel removal tool (like a spatula with a fork in it).
I'd hate to start popping them loose, then realize I can't get any plastic rivets to fit or otherwise replace them to re-mount the console bracket. . .
Old 09-13-2016, 09:54 AM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Can you post a pic? I haven't owned one.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-13-2016, 01:44 PM   #4
swissarmychainsaw
I agree on the pic issue.
You are talking about an over-head rack for CB or something?
I know that you can get plastic screws for large side mirrors (so that the screws fail and don't bend the doors).
I would check with your local NAPA or whatnot.
Otherwise take some pics!
swissarmychainsaw is offline   Reply With Quote
Old 09-13-2016, 11:12 PM   #5
Electricduane
Hello: of course I should have posted photos first. My apologies for that. I am trying to do this from my phone, so I hope the below links to the photos work properly. Thank you for your input.
https://m.imgur.com/a/Jl5FZ
https://i.imgur.com/dfKMcv7.webp
https://i.imgur.com/ULKw5E3.jpg
https://i.imgur.com/GYmR0v2.jpg
Old 09-13-2016, 11:42 PM   #6
swissarmychainsaw
Ok, gotcha, this is the overhead console thing. Found some pics here that might help others.
I would think you could grind those rivets off then either use rivets to put them back or self tapping screws, or as you say, some kind of expanding nut.
They just tie into the support cross-member thing.
Old 09-14-2016, 08:04 AM   #7
68Timber
68Timber's Avatar
Can they not be drilled out?
John
74 Honda Z50 build
Old 09-14-2016, 11:44 AM   #8
Electricduane
Yes, but my concern is that I then would have trouble getting the bracket fastened back up there after I drill them out. . .
Old 09-14-2016, 11:57 AM   #9
68Timber
68Timber's Avatar
You can pick up a decent rivet tool for pretty cheap, I think mine was less than $20 at Sears.
John
74 Honda Z50 build
Old 09-14-2016, 12:05 PM   #10
68Timber
68Timber's Avatar
Here you go: http://www.sears.com/craftsman-gener...1&blockType=G1 It comes with a few different size tips. Pick up a few different size packets of rivets, you'll be good for years.
John
74 Honda Z50 build
Old 09-14-2016, 12:14 PM   #11
Electricduane
thanks very much!
Old 09-14-2016, 01:29 PM   #12
68Timber
68Timber's Avatar
No problemo. Like a lot of tools, you don't need one often but when you do it's right on time.
John
74 Honda Z50 build
Old 09-16-2016, 12:09 AM   #13
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
hey I recognize that second pic!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-02-2016, 07:34 AM   #14
zaccaglin
zaccaglin's Avatar
I drilled mine out at the junk yard then didn't want to drill holes near my suburbans ceiling so I welded my bracket up. Cheap HF welder and my mediocre skills and it came out great.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
overhead console
