Adding Power Steering on 68 Questions
I have read a few threads concering the addition of power steering to 67 and 68 Chevys without the dimple in the frame to allow the radius of a power gear box to fit . Some folks say that if I space out the gear box with bushing material or washers, 1/2 inch, that it will work just fine. Others however, say that I will cause a bad case of bump-steer. I thought that as long as I adjusted the pitman arm the necessary number of teeth to make up for the the 1/2 to the left movement, as well as set the toe with the collars on the inner and outer tie rods, that there wouldn't be a problem. Does anyone have any suggestions or experience with the problem, to shed light on it for me, before I invest time and money in the project?
Thanks |
I thought only 67 didn't have the dimple. I converted my 68 with no problems. It was already dimpled. The dimple is easy. WES at Classic Heartbeat has a 'how to' in his panel buildup.
good luck, Scott
Silence is golden, duct tape is silver. - Scott |
Next project: 1970 K10
I just bolted my power steering gear box on my 68 tonight. Donor truck was a 72. I had to notch the bumper bracket a little, and trim the lip off of the lower rad support bracket (I think, if I remember right). Other than that, it bolted right up.
The 68 frame has the mounting holes "bumped out" about 1/2" or so from the rest of the frame, so the gear box does not bolt flat to the frame. The bump helps it to stand-off the frame. 67's may be different, but this is how my 68 is.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
