Old 03-28-2009, 08:34 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
brake proportioning valve= no reset?
I tried to bleed the brakes and don't think my portioning valve is working correctly and I don't see the reset button/pin? Here's a picture of what I've got. How can I reset this?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-28-2009, 08:59 PM   #2
Sport/Truck
Sierra Grande Club
Re: brake proportioning valve= no reset?
Is it possible to take this apart to clean/reset?
s/t
Old 03-28-2009, 09:01 PM   #3
truckdude239
truckdude239's Avatar
to reset mine i just stomped on the brakes
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-28-2009, 09:09 PM   #4
Sport/Truck
Sierra Grande Club
To be honest, I'm not sure how this happened.
I bought a new master cylinder and now I'm trying to get everything bled.
s/t
Old 03-28-2009, 09:25 PM   #5
americanmusc1e
americanmusc1e's Avatar
the reset button is on the front, it may be under a rubber cover
here's my disc brake swap thread, it may help, look near the end
http://67-72chevytrucks.com/vboard/s....php?p=3171895
I now bleed my brakes by forcing fluid up from the bleeder to the master cylinder (jack the front end up until the master cylinder is level or you may have problems) starting with the longest line and working up to the shortest line.
You can do this with the porportioning valve stuck and then after you get all the air out, close the bleeders and work the brakes, the porportioning valve should unstick itself
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-28-2009, 10:06 PM   #6
Sport/Truck
Sierra Grande Club
I don't think I have one on mine, do I? It looks like it's just a large nut with a provision for the rubber boot - minus the plunger.
s/t
Old 03-28-2009, 11:59 PM   #7
68shortfleet
Or you could use an electrical test light to verify if the valve is offcenter. When the valve is offset, the wire terminal on top is a ground to the body of the valve.
Jason
68shortfleet is offline   Reply With Quote
Old 03-29-2009, 08:11 AM   #8
truckdude239
thats why i always gravity bleed mine before i pump them up
David fuller
2000 Tahoe 5.3l 378
Old 03-29-2009, 09:45 AM   #9
gator2511
gator2511's Avatar
Comparing it to mine on my 72 you are missing the boot and plunger. My shop manual says the plunger must be held in for the brakes to bleed properly. I made a little tool for this that has a long slot that slips under the front mounting bolt and runs along the valve and turns a 90 degree angle to cover the piston on the front of the valve. I back off on the front valve mounting bolt, slip the slotted end of the tool under it and snug the bolt. Then I tap the 90 degree end to push the valve in and then I tighten the bolt. The brakes bleed easy after that. Just remove it when you are done. Without the boot and plunger I don't know what to tell you.
gator2511 is offline   Reply With Quote
Old 03-29-2009, 10:12 AM   #10
jaros44sr
jaros44sr's Avatar
Got pics. of the tool, sounds clever. I think I understand, but would like to build one, as I'm in the same boat
S/T, if you need that part, LMK
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-29-2009, 10:24 AM   #11
Sport/Truck
Sierra Grande Club
I may take you up on that.
But here's what I'm going to try.....do you think this will work?
I used a ohm meter on the warning light switch, it reads continuity, no fluid to the rear so, I'm going to tap the front on the anvil to cause the piston to shift forward until it's reading no continuity.
Think this will work?
s/t
Old 03-29-2009, 10:46 AM   #12
jaros44sr
jaros44sr's Avatar
s/t
Maybe, anything is possible...but if you mess something up, I have a complete prop. valve that was working before I bought a new one. Keep us posted on your progress. Got 2 good tips so far
I could be wrong, but isn't the reset on the front of the prop. valve
SAFETY FIRST
AS usual, off topic
Jim
Old 03-29-2009, 10:51 AM   #13
mbgmike
Here is a pic of a tool they sell.
mbgmike is offline   Reply With Quote
Old 03-29-2009, 12:22 PM   #14
Sport/Truck
Sierra Grande Club
I got it reset! I removed the switch and you can see the valve body inside. I turned in on end and taped it against the anvil it was real easy to move into place.
Thanks for all the help.
s/t
Old 03-29-2009, 09:55 PM   #15
jaros44sr
jaros44sr's Avatar
Thank you
SAFETY FIRST
AS usual, off topic
Jim
Old 08-19-2010, 01:55 PM   #16
66_k10_manny
I just installed front disc brakes complete with mc and booster on my 66 k10. Kept the rear drum. I installed a new proportioning valve complete with new lines and bled the system. My front brakes grab great but the rear brakes are locking up real easily. My pedal also feels kind of spongy. Do you think I might have a similar problem with air in the system or having to reset my proportioning valve?
66_k10_manny is offline   Reply With Quote
Old 11-11-2016, 03:38 AM   #17
robs71k5
K5drive
robs71k5's Avatar
OK I see this post is quit old but was just wondering how hard one had to hit the. Little anvil to reset the proportioning valve. I seem to have gotten my brakes back when I hit it but there is still continuity and the brakes improved immensely but could they be better? I'd like to think so!. And when you stomped on the brake where the bleeder screws open or closed ? I may have to keep at the reset untill continuity goes away?
robs71k5 is offline   Reply With Quote
Old 11-11-2016, 07:07 AM   #18
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Stomp the brakes with the bleeders closed. The OP's prop valve didn't have the indicator pin that usually protrudes when a rear wheel cylinder fails. If yours is protruding, push it back in and hold it with the tool. Then bleed the system starting with the RR, LR, FR, FL, and you should get a firm pedal with no light once the tool is removed. If you have a firm pedal and the light stays on, then give it a stomp to reset the prop valve. It's not unusual for a 45 year old system to get rust and dirt in those valves causing them to hang up. They are not rebuild-able but like the OP did, you can open the electrical switch and possibly relieve enough pressure that it will slide back to center thus opening the light circuit allowing the light to go out.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
