![]() Join Date: Feb 2009
Can anyone kindly ID these three parts please?
Picture should be self explanatory. I'm hoping for names and descriptions. Thanks for any input. Edit, that white wire runs up into a harness. Don't know what it powers, but with that and the scotch lock, it's a good guess it's not supposed to be spliced.
On a side note, this restoration business is a kick in the pants. I can see why it's a lifestyle for many. ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-12-2016 at 08:19 PM. |
![]() Join Date: Jul 2015
Re: Can anyone kindly ID these three parts please?
Clockwise, Horn Relay, Brake light switch, and finally the dreaded ignition reverse and drive starter lock out circuit.
![]() Join Date: Nov 2014
The relay - is for the horn. Whats That - is the brake light switch. Not sure on the white wire. More educated people will chime in.
toolbox is right on all three
ui would say the scotchloc is maybe done to jump the reverse light just a guess though |
Old member
Big arrow pointing down at it. Top left Horn relay. Little arrow pointing left: brake switch
Bottom is the reverse lights and neutral safety switch. It goes on the steering column when it's installed through the hole in the fire wall. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
The Older Generation
Take the wire tap off and the short white wire will come with it. You don't need it.... LockDoc
![]() Join Date: Dec 2013
toolbox is the winner , give him a lolipop
I aint nobody DORK 1972 Cheyenne super k10 swb 350 4speed posi hooks 1934 ford 3 window blown 355 1969 Camaro hugger orange hounds tooth |
Being that the white wire goes to the brake light switch, I would guess one of the previous owners may have installed a trailer brake controller.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
![]() ![]() Join Date: Jan 2015
X2 on the brake controller for a trailer
You guys will laugh, not about Guy I mean. I likely did too when this truck was new to me (1989). We worked in a shop, and my buddy, Guy, who has since been murdered (literally), was a practical joker. I believe in one instance, the horn would go off when I turned the blinker on. There was at least one other occasion, so I believe what you're looking at is brake to horn.
Correction: Post #8, BINGO. This did have a brake controller. I removed it decades ago, so I'm likely the culprit. I'll leave the above story up for entertainment value, though RIP Guy. Thanks Lockdoc on the Scotchloc. I'm rewiring this entire thing anyway. Thanks for all the responses. I don't know what a "dreaded ignition reverse and drive starter lock out circuit" is, but I'll look it up. Perhaps that's another term for neutral safety switch and it runs to the ignition? I'm just guessing here, at some point I'll chase all the wires. Thanks for all the info.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Old member
Why is it when add on electrical connections like in your picture on the brake wires people feel they need to address them. That wire could be for anything!
I don't address things like that in my answer's for one reason. I have no idea what the person who installed it was doing. The wire could be for a third brake light. Who knows what it's for. I have been working on these trucks for over 30 years and I have seen stuff that I had no idea why it was wired as it was are how in the world it even worked. And yes this is the same thing. dreaded ignition reverse and drive starter lock out circuit Neutral safety switch and back up light switch! ![]()
I got rid of my Revere, Neutral Switch Safety deal thingy.
I like my truck more better! |
#13 | |
Mine was missing one screw.That was a common theme inside this cab. But that's what I bought my 72 for: ![]() The tap was definitely for trailer brakes. In addition to that, the original owner had the following on this SWB: Step bumper W receiver hitch > fifth wheel with brackets mounted to frame, and of course bed holes. > saddle gas tanks > camper mirrors > CB > boat launching hitch. Between that and MANY loads of rocks and dirt, and the fact he bypassed the factory transmission cooler for an auxiliary, everything they say about the 400TH is true. It still feels new. I even hauled what had to have been 5-6 ton of rock in a trailer once, 30 miles. Course 25 MPH down the highway. Not the wisest decision. Building with rocks is a passion for me, but this new bed won't haul more than a blanket....That's what the 72 is for as well.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-13-2016 at 10:07 PM. |
