Long bed floor cut down for a short bed?
I have a shortbox project truck with a rusty bed floor and the opportunity to buy a wrecked long box truck that has the bed floor in good shape. I can get patch panels for the short box fenders easily but finding a replacement floor anywhere near me is difficult and I'm not really excited about trying to tie in those little bed floor patch panels.
Has anyone chopped the bed floor from a longbox down to use with shortbox bed sides? How did it go? Do you have any tips? If you've seen someone else do it on the interwebs can you post a link?
Evan B. |
Re: Long bed floor cut down for a short bed?
That would not go well...not saying: "It can't be done" however there will be some issues for sure. The crossmembers are not in the same locations due to the bed bolt spacing. The bump for the fuel necks would not be in the same location either. It would not as simple as cutting 12" off the front & 8" off the back like when you shorten the frame.
You would need to do some "funny stuff" with new bolt holes, sleeves where the crossmember normally goes, move the fuel neck bumps, ect. ect. or you would end up having 4 seams across the bedfloor to make it work. Lorne |
I have no time for this
The holy guacamole thread in the builds section has a cut down long box in it.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
#4 | |
#5 | |
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
Do you have a link to that thread? I couldn't find it using the search function.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
I did that to my 1970 C/20. May or may not be the same process as your '73-87.
The floor cut down starts at post #10 http://67-72chevytrucks.com/vboard/s...d.php?t=667694
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
He used a stock shortbox floor. He said he plans to do more of them but I don't know if he plans to cut down longbox floors or not.
Evan B. |
