02-15-2016, 10:50 AM | #51 |
Re: 1966 C1434 SWB Custom Cab
Captainfab,
Thanks I thought they looked the same. But for some reason the listing on the lower ball joints shows the press in diameter of the lower ball joints are a little different between 66 and 71. i have a little more clean up to do anyway. ill bust out the dial calipers just to confirm. I do need to change the lower driver side one because it lost a battle with a curb at one point and is twisted up at the front bushing. i know is most likely cosmetic still seems to function as intended. i hope i can get the lower BJ's out without a press. Ill try using my 6" vise
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 02-15-2016 at 12:40 PM. |
02-20-2016, 08:50 PM | #52 |
The ball joints were a breeze. now i'm just waiting on the caliper rebuild kits and the tie rod sleeves from performance online...
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw |
02-21-2016, 07:53 AM | #53 |
Looking good!!!
02-22-2016, 08:41 PM | #54 |
Now i can check the calipers of the list of things to do. also the brake lines need to be bled out. Now its back on all fours but the tie rod adjusting sleeves from performanceonline havent made it yet. I called and they said that they are scheduled for delivery tomorrow...
02-22-2016, 08:46 PM | #55 |
Here's the adjusting sleeves that performanceonline.com make for this disc brake conversion.
02-25-2016, 09:29 PM | #56 |
So here's the adjusting sleeve from performance online.com. I couldn't get the picture to turn on my phone
02-28-2016, 11:23 AM | #57 |
Added a proportioning valve from an 84 3/4 ton that had disc brakes. Should be just what I need. Running brake lines is not my specialty so after 12 feet of 1/4" line and 20 grey hairs later I managed to separate the front braking system from the rear. The original brake lines are in great shape so I just extended the line that feeds the rear brakes on the passenger frame rail to the proportioning valve on the drivers side.
03-09-2016, 10:22 AM | #58 |
Booster installed and brakes bled out once again. Stops pretty good considering
that I have only 14hg vaccuum.
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 03-09-2016 at 10:29 AM. Reason: Typo |
04-10-2016, 07:12 AM | #59 |
Looking good! Any updates??
11-12-2016, 04:14 AM | #60 |
New wheels
What better way to show off my disc brakes than with a pair of American Eagle 111's that I scored off of eBay. They are 15x8 with 3 3/4 inch back spacing and they fit perfectly.
This weekend I will be taking some photos of my axle conversion using Early Classic Industries 5 lug axle kit
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 11-12-2016 at 04:15 AM. Reason: Typo |
11-12-2016, 09:54 AM | #61 |
Nice!!!!
11-12-2016, 03:35 PM | #62 |
Axle kit
Christmas came early this year with thisEarly Classic Enterprises 5 lug axle kit complete with bearings, seals, and a differential cover gasket. I also purchased to new Rabestos brake drums for the rear to finish things off. To be continued!!
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 11-13-2016 at 09:26 AM. Reason: Typo |
11-12-2016, 03:54 PM | #63 |
Love this truck!
63 Shop Truck Build...Sorta http://67-72chevytrucks.com/vboard/s...d.php?t=722311 |
11-12-2016, 04:47 PM | #64 |
Out with the old axles and bearings. I had to hire my son as a helper so he cleaned out the tube.
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 11-13-2016 at 09:28 AM. |
11-12-2016, 05:32 PM | #65 |
My helpers salary will be Oreo's and gummies bears. The new bearings, seals, and axles are in place
11-12-2016, 05:35 PM | #66 |
Sorry guys my phone will only let me use one image at a time. Now the brakes are adjusted and drums installed. Hopefully three Jugs of lube is enough to fill it back up. The original gears are also in fine shape.
At this stage in the game it has only taken me two hours to get this far. I'll be driving it later on this afternoon
11-15-2016, 06:59 AM | #67 |
Saaaaweeet! You gotta luv buying parts that fit with no mods!!!!
11-15-2016, 07:45 AM | #68 |
Heater Core restoration
So my heater core died in me about a week ago. The new one will be in today sometime. In the meantime I have cleaned and painted the heater box with satin black paint.
The damper door inside the box used to have some type of black rubber foam glued to it seal the hot air duct while slowing cool air to flow. Any suggestions on what I should use to replace the original foam
11-15-2016, 01:15 PM | #69 |
PM me your address and I'll send you the right stuff. I bought a whole roll from McMaster-Carr and have plenty left over.
11-16-2016, 07:40 PM | #70 |
Here are all the heater box parts cleaned up ready for assembly. Turn the clock back one detail at a time.
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 11-17-2016 at 08:20 AM. |
11-16-2016, 07:42 PM | #71 |
More images
11-16-2016, 07:43 PM | #72 |
Last of em
11-21-2016, 07:55 PM | #73 |
Working out the kinks, the heater blows blistering hot now. The damper has a new gasket so it gets TO hot in full recirculating mode. ����
Thanks to Nick with Aspen Auto who sent me a heater core strap and the input and experience from others that made it such a smooth repair.
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 11-21-2016 at 08:36 PM. |
02-23-2017, 03:54 PM | #74 |
Just an update now. Now I have the wheels for the back have to say looks pretty sharp. In these photos the front wheels are two piece and the rear are one piece. The two piece look wider so I put em in the back.
02-23-2017, 03:55 PM | #75 |
Round two
