#51 |
Re: '63 c10 drag build
Did you see that video of freight train loosing traction and nearly eating the wall
#52 |
Some progress pics
#53 |
That looks badass!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#54 |
Looking good! I see you got the lower part of the front fender mounted and looks like you lopped off a bit of the frame for the rest of the front end to fit. Cant wait to see it making passes!
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#55 |
Following!
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks ![]() |
#56 |
dam nice build. wanna redo back half and cage. which cage u go with?
#57 |
#58 |
Got a little more involved had to cut headers and go to a motor plate which is a one off Cnc'd deal kind of a nightmare with the steering
#59 |
Looks good. Hoping to make a few races down there next season.
#60 |
Getting all the last pieces of the puzzle on taking it to a chassis guy to align and set up suspension but I refuse to push it onto a trailer that's for trucks that don't run so let's hope it survives the first parking lot burner
#61 |
Looks great!!
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
#62 |
60-66 Nut
Whose 'glass nose are you using?
#63 |
#64 |
Sick truck!!!!!!!
#65 |
#66 |
Whos front crossmember did you use?
#67 |
Scott's HotRod with the double adjustable shock
I had my own Chris Alston spindles though |
#68 |
All buttoned up guess have to start a new thread c10 drag trial
#69 |
![]() Join Date: Mar 2008
Looks great Gomez. Now go burn some rubber.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
#70 |
Awesome!!!
#71 | |
I am trying to find a cheap match for discs..
my build http://67-72chevytrucks.com/vboard/s...d.php?t=210902 |
#72 |
Digging up the old thread because we are building again
#1 nitrous is to expensive on the west coast and it's hot as a mofo in NorCal so babying bottles in a hassle #2 Nitrous is hard on things So I've gone to the Darkside. I'm also going to a 750 cage. And doing some simple things here and there to stop frame twist/bow |
#73 |
Nice! Gonna be ready for KAN?
#74 |
#75 |
In a turn of events I've seen to misplace one of the two turbos after I left Bakersfield as the fastest truck🤷*♂️
https://www.instagram.com/p/Brk-QhDA...=1cbbyqjr2gjfl |
