Old 11-06-2016, 04:56 PM   #1
gafiredog
wheel spacers
I have a 1 ton single wheel crew I'm starting to work on after a few years of it being on the back burner. Can I put 3" spacers on the front and use 1 ton wheels? has anybody done this? thanks, Art
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 11-06-2016, 05:09 PM   #2
nonstop
Re: wheel spacers
Is this a 2 wheel drive? If it is, you're probably money ahead getting dually rotors and hubs.
nonstop is offline   Reply With Quote
Old 11-06-2016, 06:00 PM   #3
UKNOWME
UKNOWME's Avatar
Re: wheel spacers
What are you trying to accomplish? Just curious
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 11-06-2016, 06:59 PM   #4
gafiredog
Re: wheel spacers
2 wheel drive. changed over a 3/4 ton to one ton wheels years ago, had to change spindles because the calipers from the 3/4 ton won't fit the 1 ton rotors. was just wondering about spacers. less headache to bolt on wheel spacers than change everything from spindles out. this truck has c-30 plates, and 10,000 gvw on sticker on door post with all the other info. about the truck, but it has 3/4 ton front brakes, with a 14 bolt rear like the 1 tons do. may want to run 1 ton bud wheels on it.
Art
1975 c-10 stepper
1987 crewcab dually
Old 11-06-2016, 08:56 PM   #5
UKNOWME
UKNOWME's Avatar
Re: wheel spacers
My 3/4 has a 14 bolt. The rest of what you said confused me but that doesn't take much. Lol
1964 Chevy c10
Old 11-07-2016, 03:01 AM   #6
andrewmp6
Re: wheel spacers
Honestly i wouldn't drive anything with a 3 inch spacer specially with a heavy dually wheel on it.Its a lot safer just to swap out the dually parts and is what i would do.
Old 11-07-2016, 07:26 AM   #7
cadillac_al
Re: wheel spacers
I'm pretty sure he's talking about the front end, converting regular steel wheels to the heavy duty 1 ton wheels. I have never messed with those heavy duty wheels and don't really know what the spacer looks like other than what I see through the wheel. I don't really think it cam be done. I always thought the steel wheels looked better to me.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 11-07-2016, 07:53 AM   #8
andrewmp6
Re: wheel spacers
He wants budd wheels which are dually rims.He wants to use really thick bolt on spacers insted of doing a dually swap on it.
Old 11-07-2016, 08:24 AM   #9
74CustomK20
74CustomK20's Avatar
Re: wheel spacers
Do a dually swap. That is a lot of leverage on those spacers.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 11-07-2016, 08:25 AM   #10
95 S_Trucker
95 S_Trucker's Avatar
Re: wheel spacers
The best thing to do would be to change the rotors to 1 ton rotors.
I would look at factory 1 ton express van/silverado adapter/spacer if you want to use a spacer.
01-10 from dually trucks, and 03-current for dually express/savanna vans.
The lug pattern is the same, the hub diameter is the same, the new studs will be 14mm. You may be able to replace them with 9/16 or just get metric nuts.
95 S_Trucker is offline   Reply With Quote
Old 11-07-2016, 08:26 AM   #11
95 S_Trucker
Re: wheel spacers
Old 11-07-2016, 03:01 PM   #12
UKNOWME
UKNOWME's Avatar
Re: wheel spacers
Is it's making sense. What's your plan for the rear? I'm asking these questions because I'm considering converting my 3/4 to a dually. Not so much for extra load as much as looks. I'm planning to lower mine though
1964 Chevy c10
Old 11-08-2016, 04:27 AM   #13
andrewmp6
Re: wheel spacers
A dually rear end is wider then a single wheel rear end.But a cab and chassis dually rear is the more narrow then a single wheel rear end.Top dually swap you need the bed the rear end,The front end you need spindles out and maybe tie rods.
Old 11-08-2016, 10:03 AM   #14
SCOTI
SCOTI's Avatar
Re: wheel spacers
The hub bore changed when the lug studs did (from my research on the subject/looking for wheels).
Pre 01 was 1/2" studs/4.56" hub bore. Post used 14mm studs & have a 4.60" hub bore. Not much difference but different enough to matter.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-08-2016, 05:15 PM   #15
95 S_Trucker
Re: wheel spacers
The metric studs started in 88(with the gmt400 trucks)
Everything I saw with hub diameter is 117 mm.
Maybe an adapter from a 88-00(IFS) 4wd DRW?
Old 11-08-2016, 06:21 PM   #16
SCOTI
SCOTI's Avatar
Re: wheel spacers
Since squarebody CC duallys were available thru 91 & did not have metric lugs, I guess there are variances. I know from my search for clean steelies through Southwest Wheel, the years w/the different bore sizes were listed as 73-00 @ 4.56" bore & 01-07 @ 4.60" bore. After that they were listed as metric.
They sell conversion adapters to allow mounting dually style wheels on single wheel apps....
https://www.southwestwheel.com/c-103...-adapters.aspx
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-12-2016, 03:15 PM   #17
Desert1957
Desert1957's Avatar
Re: wheel spacers
Here is was my thread, I think it should give you an idea before and after.
http://67-72chevytrucks.com/vboard/s...d.php?t=581002
Desert
Desert1957 is offline   Reply With Quote
Old 11-16-2016, 05:49 PM   #18
gafiredog
Re: wheel spacers
thanks for all the input guys. Think I'll just go with the 1 ton parts and do it the way I did before. getting lazy in my old age and wanted the look and an easier way to get it, thats all.
Art
1975 c-10 stepper
1987 crewcab dually
