Old 11-15-2016, 07:11 PM   #1
Hug E Bear
Frame Identification
I just purchased a 1965 "C20" to restore. Turns out, the vin # on the cab and the title confirm it is a 65 C10. The problem I am having is that the serial number on the frame is behind the cab on the passenger side top frame rail. I know for the 65 that the serial number should be either on the driver side frame rail right in front of the upper a-arm or on the driver side frame rail underneath the cab. The first part of the serial number is 1CAZ..... I haven't been able to find any chevy frame identification numbers that start with those particular letters. It is a coil spring/disc brake front end with leaf spring chevy 14 bolt rearend and it is 8 lug. Any help is greatly appreciated. I want to make sure I get the correct parts for the chassis and suspension.
Hug E Bear is offline   Reply With Quote
Old 11-15-2016, 07:56 PM   #2
tismy65
Re: Frame Identification
The frame ID # should be the same as the VIN# found on drivers side under cab.
tismy65 is offline   Reply With Quote
Old 11-15-2016, 08:21 PM   #3
Hug E Bear
I've looked in both places and have no vin# stamped on the frame. The only one is on the frame, under the right front side of the bed. I'll post the complete number when I get home tonight.
Old 11-15-2016, 09:15 PM   #4
PGSigns
PGSigns's Avatar
Pictures would help a bunch. Show the cab mounts.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-15-2016, 10:33 PM   #5
Hug E Bear
Here is a pic of the number that's on my frame.
Old 11-15-2016, 10:59 PM   #6
padresag
the frame is a GMC frame usually if it has rear leaf springs.
they do not put the whole vin nbrs on the frame. the last 5 or 6 digits from the frame sould match the last 5 or 6 on the vin plate. that is the production # and that shpo;d match. GMC frames of these years did not seem to the ser# on them.
sounds like someone perhaps stuck a GMC 3/4t frame umder a Chevy c10 body
this is what happens when these guys cobble all of this crap together and dump it off on someone witout doing the proper registration
ron
padresag is offline   Reply With Quote
Old 11-16-2016, 12:26 PM   #7
Hug E Bear
Well, I spent all night looking online for anything that could tell me what year this gmc frame is and i found nothing. The last 6 digits don't match the title or vin plate because the title is for the 65 c10 cab. I'm not sure how different the 3/4 ton frames were between the different years of gmc trucks but I just don't want to spend money on parts that are for the wrong year.
Old 11-16-2016, 01:23 PM   #8
bpmcgee
bpmcgee's Avatar
Hug,
I agree that it doesn't line up very well with any VIN scheme I can find for GM. "1C" looks like the beginning of a '61 Chevy VIN, but it wouldn't be followed by two more letters. The two letters together looks like a GMC VIN, but it wouldn't have THREE letters.
'72 vins DID have 3 letters, but I can't find any reference to "A" being a valid letter in that position.
Two thoughts -- is it possible that it's NOT a VIN but a part number? And second -- it's also possible to identify a frame by the dimensions of the frame members. That information is well documented. Care to post a picture and frame member dimensions for us to cross-check?
Brian
bpmcgee is offline   Reply With Quote
Old 11-16-2016, 02:50 PM   #9
61K10
61K10's Avatar
As PGSigns said need pics of the cab mounts (how the cap is mounted). whateng? power steering? more pics needed.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-16-2016, 07:41 PM   #10
Hug E Bear
Front cab mounts are intact. Rear cab mounts have been cut off. Truck does have power steering but didn't come with an engine. I have a 4 speed manual transmission that came with the truck but who knows if it was the original one. I will try and move the cab off of the frame tonight and post a picture of just the chassis. Thank you everyone for your help.
Old 11-16-2016, 09:22 PM   #11
PGSigns
PGSigns's Avatar
The more pics of the frame the better. The front where the bumper mounts also helps.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-17-2016, 01:14 PM   #12
Hug E Bear
I didn't get a chance to pull the cab off the frame last night but I did get some pics of the bumper mount and front of the frame. I'll try and get the cab off tonight.
Old 11-17-2016, 01:23 PM   #13
jtrichard
That looks to be a 73 and up frame
jtrichard is offline   Reply With Quote
Old 11-17-2016, 02:38 PM   #14
bpmcgee
bpmcgee's Avatar
This thread has dimensional drawing of all years 60-66 frames. Do your frame measurements line up with the '65?
http://67-72chevytrucks.com/vboard/s...d.php?t=325736
Old 11-17-2016, 10:45 PM   #15
jtrichard
from the frame location (right rail half way from cab to axle) and what I can find about vin break down it looks to be 1980 Fremont truck
Old 11-18-2016, 02:27 AM   #16
Captainfab
60-66 Nut
I agree. It is a '73+ frame.
Old 11-18-2016, 03:17 AM   #17
Kenfuzed
Kenfuzed's Avatar
Just out of curiosity, what indicators from these photos would identify this is as a 73+ frame? I'm always trying to educate myself so when looking at these trucks for friends I can spot the differences in various years.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 11-18-2016, 07:45 AM   #18
PGSigns
PGSigns's Avatar
What I see is the shape, the formed section for the power steering, the spot for the brake lines for the front disc brakes, The body mounts and the bumper slopes the other way.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-18-2016, 10:37 AM   #19
Hug E Bear
Thank you everyone for the help. I really do appreciate it.
Old 11-18-2016, 12:23 PM   #20
jtrichard
Jimmy
X2 above...YES bumper, mounts, brake line location,PS gear indent, front frame member. engine mounts,fuel lines,charcoal canister line from gas tank, NOTHING looks like it has been modified from late frame to a pre 72 frame
Old 11-18-2016, 04:31 PM   #21
Hug E Bear
So we're definitely looking at a '73-'80 3/4 ton chassis?
Old 11-18-2016, 09:23 PM   #22
jtrichard
YES ......I would put money on it
Old 11-18-2016, 10:31 PM   #23
Slow Build
Slow Build's Avatar
I'm not a frame expert but it does look like the frame horns aren't 63-66. But those lower control arm bushings look like pre 73 with zerk fittings.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-19-2016, 01:07 AM   #24
Captainfab
60-66 Nut
I see the same things as PGSigns and jtrichard as well as the style of engine mounts
The '73+ C20 and C30's did not have the rubber control arm bushings as the C10's do. They retained the greasable steel control arm bushings that the '72 and earlier C10,20 and 30's did.
Old 11-19-2016, 01:21 AM   #25
Slow Build
Slow Build's Avatar
I learn something new every day. Unfortunately I forget two things I used to know in the same amount of time.
Thanks for the knowledge.
Past GM Trucks:
