87 fuel senders
I Have An 87 Duel Tank Short bed And I Have 3 Choices
#1 Drop The Tank #2 Lift The Bed Up #3 Cut The Bed Open To Get To The Tank Senders That Would Be Very Easy The Go To Junk Yard Cut Old Bed panels Screw Then On Top Of The 2 Holes, Put The Bed Liner Back Then I'm Done. I'm 74 And I'm Not Going To Do All That Hard Work What Do You Folks Think ? Harley03joe Click here: 87 chevy r10 Gas Dual Tank Selector Valve - AOL Video Search Results ![]() ![]() |
Gentleman Jim Driver
Re: 87 fuel senders
The sender is right under the cab to bed union. There is no easy opening to just cut in the bed to get access. Look down between your bed and cab and you will see the sender.
Pulling the tank is necessary. I pull the bed to pull to the tank. Its proven to be more work but save a lot of frustration for me.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#3 | |
Re: 87 fuel senders
YOUR so right The Sender Is Under The Cab Dame ,, Not An Easy Job, Thank You For The Heads UP Your A Great Person. Im Going To Change The Gas Dual Tank Selector Valve First I Already Replaced The Switch In The Dash. I'm Just Moving Along On This Job Little By Little I Guess Thank You Again, I'm Going To Remove The Post About Cutting The Bed Open Thanks Again Harley03joe ![]() ![]() ![]() ![]() |
Re: 87 fuel senders
Removed By Harley03joe
Re: 87 fuel senders
Re: 87 fuel senders
removed by harley03joe
Re: 87 fuel senders
#8 | |
Re: 87 fuel senders
You Know What I Done, I Took The Easy way Out, Ha Ha I Took My Truck Over To The Good Year Service Center, And They Are Going To Pull Both Tanks Replace The Senders & Pumps A/C Delco Parts Along With The Selector Valve, Put In My Fuel Filters And Replace The Oil Sender That's Leaking A Little, And New Electoral Connectors All 3 Of Them I Told Them To Solder Them And Shrink Rap Them, And To Lift My Truck On The Frame NOT THE BODY Also Change The Oil And Filter Also Do A Diagnostic Check On The Computer ![]() ![]() ![]() Happy Happy Happy Camper Thanks For Shedding The Light On Things Harley03joe Last edited by Harley03joe; 11-16-2016 at 09:42 PM. Reason: words |
Re: 87 fuel senders
Re: 87 fuel senders
Too bad you were not closer, I would have told you to come by.
I removed and replaced my fuel tank pump in less than 30 min total. Rubber hose in the tamk normally solves alot of issues. |
#11 | |
![]() Quote:
I Had Some Extra Cash So I Went To The Good Year Repair Shop, I'm 74 And Not Going To Lay Under A Truck And Bang My Arms Up, They Already Look Like Chop Meat Ha Ha Ha Let Someone Else Do It ![]() Thank You Very Much For The Offer To Help Me Harley03joe ![]() ![]() ![]() Last edited by Harley03joe; 11-19-2016 at 04:09 AM. Reason: words |
