Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 11-19-2016, 05:14 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: A guy from the 67-72 side with some questions...
I am 5/11 at 215 lbs and have a 42 rod and a stock 46 which is near stock. I figure 6/2 is about max in the 42 which has a seat tank and custom platform for the 2 jeep buckets plus a 67 non tilt colum. You would be near the top of the windshield for line of site seeing up less than I can. The 46 which has a seat tank and the stock seat is about the same as my 42. The seat backs are near to the back of the cab now with no more adjustment back on either. I am not sure you would gain much with the tank out of the cab. My suggestion is to find someone who will let you sit in their truck. I am a little far from you unless you are passing thru.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
