Re: Repo Front fenders, 65 c10
Both of fenders are repos on my truck. I had the same problem with gaps on the front. When I had it painted for the second time the painter used seam sealer in all the gaps to give it a more finished look.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
![]() Join Date: Jan 2012
So, I painted my fender, to put a base coat on and to get some practice painting.
I REALLY should've test file it first. Everything looked damn close, and it was, except for one area. The area that bolts up to the air vent / cowl area. The angle on the bend in the area pointed to in the first picture needed to be a bit more acute. Because it of this, the top fender bolt holes BARELY reached and that was after some manipulation. I also seam sealed the gap like t62 Barnfind had done. |
