Closed Thread
Old 11-17-2016, 12:40 AM   #4626
weq92f
weq92f's Avatar
Re: What did you do to your truck today? Chapter II
Sat under the hood with my butt on the driver side mounted battery, my phone camera in one hand, the shop light in the other and repeatedly attempted to shoot a picture of the casting numbers and date code on the back of my block. I have a ton of shots of the bell housing, back of the head, wiring harness, rear of the intake manifold, oil pressure sending unit, transmission bolts going into the mounting flange, blackness and very overexposed whiteouts. It took far too long to get the shot. A mirror made quick work of it in the end ( top tip! ).
weq92f is offline
Old 11-20-2016, 01:46 PM   #4627
Possmguts
Possmguts's Avatar
Ordered everything to get my bed converted to the wood bed last night... now the wait... and then the finding time to get on it...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 11-20-2016, 04:41 PM   #4628
66clow
66clow's Avatar
Decided to put in my one piece back glass. Was a tough one man job. Painted the white letters on my gate. Painted my column.
66clow is offline
Old 11-21-2016, 09:17 PM   #4629
LongBox
After reading about cowl rust issues and repairs with the 67-72s, I decided to get down on the pavement, and clean out the body drain holes. I was mostly concerned with making sure that there was no dirt or decayed leaves and needles in the area between the cowl and the front fenders, so I used one of those plastic ties to get into the drain holes and pull out anything that would hold moisture. The left side had some crud in there, but the right side was clean. Also did the doors, and rinsed them out to make sure all the drain holes flowed properly.
Finished up by washing out the front "horns" at the bottom of the fenders, and hosing off the underside of the truck.
No bad surprises, so I'm tired, dirty, but happy. My thought is that if I keep on top of stuff like this, I can keep the tin worm away.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline
Old 11-21-2016, 09:25 PM   #4630
LongBox
Rick
LongBox is offline
Old 11-21-2016, 10:34 PM   #4631
Metaldoc
Metaldoc's Avatar
Be pro active really helps I also sprayed fluid film down inside the cowl vent holes in the cab to rust proof. I did the inside bottom of the doors too.
Metaldoc is offline
Old 11-22-2016, 01:17 AM   #4632
long72
Took some pictures today to learn how to post them.
Thinking about what I want to do to this truck.
72 C10
38 Chevy Tudor Sedan
40 EL Knucklehead
03 Road King Classic
long72 is offline
Old 11-22-2016, 01:46 AM   #4633
VWNate1
VWNate1's Avatar
Exclamation What Tod Do ?
You have a nice old LongBed in Wyoming ~
Love it , take good care of it so the tin worm doesn't eat it out from underneath you, DRIVE and enjoy it plus work it ~ that's what GENERAL MOTORS LIGHT DUTY TRUCKS were made for .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 11-22-2016, 11:00 AM   #4634
long72
We are pretty fortunate here in Wyo, very dry weather and no salt is used on the roads. most vehicles here have no or very little rust.
This truck was purchased new in Powell, Wyo. it has spent it's whole life here.
72 C10
40 EL Knucklehead
long72 is offline
Old 11-22-2016, 11:02 AM   #4635
long72
72 C10
40 EL Knucklehead
long72 is offline
Old 11-22-2016, 02:06 PM   #4636
VWNate1
VWNate1's Avatar
Post RUST Issues
Understood .
Be aware that even in the California Deserts these trucks tend to rust out because GM dropped the ball and didn't make any effort to prevent rusting .
This is why it's so critical to keep an eye on rust and be pro active .
I hope you'll do a major Service and tune up on it then DRIVE it as they're very good drivers .
-Nate
Geezer
VWNate1 is offline
Old 11-22-2016, 09:37 PM   #4637
SoCoC10
SoCoC10's Avatar
Hung the driver's side trim on the new bed sides.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 11-23-2016, 01:42 AM   #4638
66clow
66clow's Avatar
Started on my steering wheel resto.
66clow is offline
Old 11-23-2016, 01:17 PM   #4639
weq92f
weq92f's Avatar
That truck looks nice! Love it!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 11-23-2016, 01:41 PM   #4640
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Does your truck have a plaid seat ? If so check out the link below and it would be good if you could post some pics of your truck along with picture of the spid label on that thread.
http://67-72chevytrucks.com/vboard/s...38#post7775838
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 11-23-2016, 03:31 PM   #4641
Andy4639
Old member
Andy4639's Avatar
Question Re: What did you do to your truck today? Chapter II
Is it me are is his brake pedal off. It looks like it's bent over pretty good to me.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 11-23-2016, 04:24 PM   #4642
66clow
66clow's Avatar
No I think it is the angle of the photo. Don't think I could drive it that close together.
66clow is offline
Old 11-23-2016, 06:25 PM   #4643
ole dollor
ole dollor's Avatar
[QUOTE=Andy4639;7776031]Is it me are is his brake pedal off. It looks like it's bent over pretty good to me.
Andy it sure looks bent to the right to me .....Don
ole dollor is offline
Old 11-23-2016, 11:00 PM   #4644
66clow
66clow's Avatar
Finished painting the wheel
66clow is offline
Old 11-24-2016, 12:02 AM   #4645
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Looks nice ! .
How about the details of how you cleaned it , what used to fill the cracks and what kind of paint used ? .
-Nate
Geezer
VWNate1 is offline
Old 11-24-2016, 12:38 AM   #4646
66clow
66clow's Avatar
Originally Posted by VWNate1 View Post
Looks nice ! .
Body filler, sandpaper and rustoleum. Thanks
66clow is offline
Old 11-24-2016, 06:36 AM   #4647
VWNate1
VWNate1's Avatar
Thumbs up Steering Wheel Service
Thanx ! .
What did you use to clean it first ? .
I just bought an old ('59) VW Beetle and the steering wheel is in O.K. shape but filthy and the original paint is worn through .
-Nate
Geezer
VWNate1 is offline
Old 11-24-2016, 10:38 AM   #4648
70cst
70cst's Avatar
Picking up this slider up for $60 tomorrow
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Old 11-24-2016, 02:56 PM   #4649
findog78
Bummer. I couldn't give mine away for $25. I ended up tossing it when I moved.
findog78 is offline
Old 11-24-2016, 03:56 PM   #4650
VWNate1
VWNate1's Avatar
Post Slider Backlights
Most Californians take them out, other places less so .
I always remove them and then can't give them away .
I try to give away left over parts because so many have helped me as I go along...
HAPPY THANKSGIVING.
-Nate
Geezer
VWNate1 is offline
Closed Thread
