Old 10-16-2016, 06:10 PM   #1
warriorsimi
Leaf to trailing arms how to ?
Can I get some help on what is needed to swap from leafs to trailing arms for my 72 GMC with 5 x5 lug pattern.thanks in advance.
warriorsimi is offline   Reply With Quote
Old 10-16-2016, 07:21 PM   #2
GR8-68
GR8-68's Avatar
Re: Leaf to trailing arms how to ?
Quite a bit, crossmember where trailing arms attach, trailing arms, drive shaft, rear axle housing, tracking bar, tracking bar frame bracket, coil spring frame perches, coil springs, shock mounting crossmember, and time and knowledge to get it back together. I believe I thought of it all.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-16-2016, 07:32 PM   #3
notsolo
notsolo's Avatar
If you are going to go with original parts find a donor truck with trailing arm cross member trailing arms and springs, axle with correct welded mount. You will need to build spring perches for the frame. Frame on a leaf spring truck were straight, trailing arm trucks the frame bows out where the spring mounts.
notsolo is offline   Reply With Quote
Old 10-16-2016, 07:36 PM   #4
GR8-68
GR8-68's Avatar
Oh wow ! Didn't know that. Better off finding the whole frame to swap out
Larry
"Project 68"
paypal.me/ldgrant
Old 10-16-2016, 08:11 PM   #5
warriorsimi
Wow that is a lot of work thanks for the replies I think my only option is a four link set up so I can keep my axle with the 5 lug.
Old 10-16-2016, 09:18 PM   #6
Jeff's bowtie's
Leaf spring 2 wheel drive and coil spring frames have the same bowed out frame rails the 4 wd are straight frames and C/30 leaf frames are straight
Jeff's bowtie's is offline   Reply With Quote
Old 10-16-2016, 10:31 PM   #7
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
I was just going to say the same thing. I converted my '71 GMC to coils in the rear and other than the trailing arms and all the hardware, the crossmember was there and the frame was bowed in the right spots to accept the springs!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 10-17-2016, 09:17 AM   #8
warriorsimi
The spring mounts do not matter cause I am bagging it.the only thing I am concerned about is the pan hard mount on the frame and keeping the 5 lug.can I swap axle shafts from 6 lug to 5 lug?
Old 10-17-2016, 11:20 AM   #9
StingRay
StingRay's Avatar
There is a 6 lug housing from the 1970 model year that will accept either 70 6 lug or 71 up 5 lug. Those 70 6 lug will swap up years as well. Earlier housings are too short for later axles and require an aftermarket axle or re-machining of the originals.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 10-17-2016, 12:18 PM   #10
warriorsimi
Thanks for the info ,glad I joined the forum there sure is a lot of knowledgable forks here.
Old 11-20-2016, 05:15 PM   #11
jr1966
Is there a problem if you just want to swap the complete axle housings only from a leaf truck to a trailing arm truck ?
jr1966 is offline   Reply With Quote
Old 11-20-2016, 05:26 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The rear brake lines are routed completely different too.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 11-21-2016, 05:19 PM   #13
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Have a look at this. It's a reasonable compromise to a full axle swap.
https://www.youtube.com/watch?v=vS_5xwt1_io
suprachrgd82 is offline   Reply With Quote
Old 11-23-2016, 09:24 AM   #14
jr1966
Smile Re: Leaf to trailing arms how to ?
Why do you have to change drive shaft in this swap ? and if the truck is a trailing arm truck what needs to be done to adapt a leaf spring axle to the trailing arms ? I am needing to do this also
Thanks Good info here for a new to trucks guy
Old 11-23-2016, 09:54 AM   #15
bsampson
Originally Posted by jr1966 View Post
... and if the truck is a trailing arm truck what needs to be done to adapt a leaf spring axle to the trailing arms ? I am needing to do this also
I don't know on the driveshaft. Maybe a slightly different length?
A leaf spring axle would be missing the correct saddles and a panhard mounting location.
This looks to be a pretty complete kit:
https://www.performanceonline.com/19...onversion-Kit/
bsampson is offline   Reply With Quote
Old 11-23-2016, 10:19 AM   #16
jr1966
That looks like a good start on the changeover. Hope the driveshaft is the same but the frame I am using from has one I think.
