#1 | |
Re: 49 ls1
It appears that you have welded the wrap around ends to the door panel, which then makes the window surround trim impossible to remove. How did you engineer that so the window surround can be removed? Are you eliminating the rubber weather stripping that seals the inside of the door to the door jamb? Thanks, |
#2 | |
![]() Join Date: Apr 2010
Re: 49 ls1
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
