Old 09-04-2016, 02:27 AM   #226
Nut Case
Nut Case's Avatar
Re: 1959 short Fleetside Apache AKA "Henry"
"CMAC"
Hey it isn't old it's "Fresh"!!!
You just freshened it up.
Great job, strong work
Keep on keepin on
Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-04-2016, 06:05 AM   #227
dug224
dug224's Avatar
Stunning!
dug224 is offline   Reply With Quote
Old 09-04-2016, 09:23 AM   #228
Foot Stomper
Foot Stomper's Avatar
4000 miles? That's clearly "daily driver" status! Fantastic!
great looking truck!
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 09-04-2016, 04:41 PM   #229
murd969
Nice looking build. I like the way it turned out. I'm going through similar issues with gaps etc with my doors now so I know exactly what you went through.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 09-05-2016, 07:45 PM   #230
CMACDONALD1
CMACDONALD1's Avatar
Thanks guys! It's been a blast this summer and hopefully we have a decent fall before it gets tucked away for winter.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts.
1972 Cheyenne Short Bed
1958 Apache short fleet
1980 Chevy short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=761005
1959 "Henry"
http://67-72chevytrucks.com/vboard/s...d.php?t=670461
1966 Biscayne
http://67-72chevytrucks.com/vboard/s...d.php?t=444419
1972 Suburban
http://67-72chevytrucks.com/vboard/s...d.php?t=478828
CMACDONALD1 is offline   Reply With Quote
Old 09-08-2016, 08:23 AM   #231
lower50's
lower50's's Avatar
4000mi is awesome!!! Truck is looking great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-08-2016, 05:41 PM   #232
CMACDONALD1
Thanks Lower50's.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 10-15-2016, 02:17 PM   #233
Fleet '66
Active Member
Fleet '66's Avatar
Thumbs up Re: 1959 short Fleetside Apache AKA "Henry"
I just finished reading your entire thread. You have a beautiful truck and did a great job on documenting the build. I hope you get to enjoy all the hard work and are able to put on another 4000+miles in the next season.
I have always liked the TF fleetsides. I picked up a short fleet box for my '58 step side a while back and hope to either convert the '58 or find another recipient for it.
Fleet '66
'66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade
'64 C-10 LWB BBW near future project - "The Wife's Ride"
'58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show
Fleet '66 is offline   Reply With Quote
Old 10-15-2016, 03:19 PM   #234
CMACDONALD1
Thanks Fleet 66! Truck is officially parked for the winter. I picked up a overdrive transmission recently so I will be putting that in within the next few weeks. Yeah I hope to put a few miles on next summer for sure and it will be a lot better with an overdrive.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 10-17-2016, 07:36 AM   #235
lower50's
lower50's's Avatar
So much more comfortable with OD, and should be better on fuel.
1951 MG TD
Old 10-17-2016, 03:39 PM   #236
CMACDONALD1
I should have put an overdrive in right away but the turbo 350 just worked too good to warrant a change out. Now that I have made a few longer trips with it that overdrive will be awesome.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-24-2016, 01:51 PM   #237
CMACDONALD1
Finally was able to find a little bit of time to pull out the turbo 350 and get the overdrive in. Just waiting for my drive shaft to get finished up and add oil.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-24-2016, 07:49 PM   #238
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
The 700R4 was one of the best mods so far for my truck, you're going to enjoy the overdrive for sure!!
ChuckDriver is offline   Reply With Quote
Old 11-25-2016, 11:51 AM   #239
CMACDONALD1
I'm really looking forward to taking it out for a drive. I still have to figure out the best way to hook up the lockup converter.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-25-2016, 12:53 PM   #240
RockinKees
RockinKees's Avatar
I'm with Chuckdriver, the best swap you'll ever make!!!
I hooked up the converter with a manual switch, via a relay connected to the brakeswitch, so if you hit the brake, the lock up falls off.
It works for me
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-25-2016, 11:26 PM   #241
ChuckDriver
I used this from Bowler Transmission, works great!
https://www.bowlertransmissions.com/...ontrol-module/
Old 11-26-2016, 12:50 PM   #242
CMACDONALD1
I will have a look into this option for sure. Thanks chuckdriver.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-06-2017, 06:15 PM   #243
CMACDONALD1
Snow has once again arrived and sadly the truck is back into hibernation. Was a great season of cruising though.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-06-2017, 07:25 PM   #244
Russell Ashley
Russell Ashley's Avatar
Looks like a nice place to hibernate. Nice rides and shop you have there.
Russell Ashley is offline   Reply With Quote
Old 11-06-2017, 07:33 PM   #245
Dan in Pasadena
Dan in Pasadena's Avatar
Can you tell me what rims, sizes & tires you’re using? Any closer photos? They look to be EXACTLY what I had planned on using on my ‘55 until I got a deal on some BOyds Smoothies that i’m Not sure I’m in love with.
Great looking truck!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 11-06-2017, 07:39 PM   #246
CMACDONALD1
Thanks! Yeah its not a bad place to hibernate haha.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-06-2017, 07:46 PM   #247
CMACDONALD1
I will dig up some pictures and tire sizes for you.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-06-2017, 08:28 PM   #248
CMACDONALD1
I have staggered wheels 20’s on the rear and 18’s on the front the rear tires are 255 45 20 and the front are 235 50 18. Sorry my phone turns the pictures sometimes for some reason but you can get a good idea of what the rims look like.
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 11-07-2017, 12:38 AM   #249
lower50's
lower50's's Avatar
Nice play house. Snow is coming here soon too.
1951 MG TD
Old 11-24-2017, 02:36 PM   #250
slammed57
wheww! love this truck great stance and the bed looks killer!
slammed57 is offline   Reply With Quote
