Old 03-21-2004, 04:18 PM   #1
CG
BlahBlahBlah
rusty nuts and bolts
whats the best rust breaker for nuts and bolts that you cant torch off?
Old 03-21-2004, 04:38 PM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
pb buster
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 03-21-2004, 04:53 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
Another vote for PB Blaster....great stuff....just spray whatever you need to loosen, let it soak overnight, and it works great.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-21-2004, 06:19 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
PB blaster is awsome.
Mobile one has a better spray, but it is kinda pricey.
Some gun shops have stuff that works miricles.
What is it you can't put heat to?
Old 03-21-2004, 10:01 PM   #5
rolson1039
i tried the PB Blaster this weekend and it didnt do a dern thing. If im able i use my dremel to slice the nut open with the cutoff wheels and then i can usually use the usual methods to get the nut off.
Ive used liquid wrench and the clark version of penetrating oil and none of it really works spectacularly
The PB Blaster does work well as a lube/coolant for when youre drilling
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 03-21-2004, 10:04 PM   #6
1971 Cheyenne
1971 Cheyenne's Avatar
I've never had too great of luck with all the "liquid wrenches" out there, I've found that a good impact wrench or a good set of 1/2 in. sockets and a huge cheater bar seem to work best! good luck!
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 03-21-2004, 10:15 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have had great luck with P.B. and the LIQUID WRECH stuff..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-21-2004, 10:37 PM   #8
ACES
Life is a gamble
ACES's Avatar
pb
I like PB blaster, but for tough bolts, it helps to use it several times. Like once a day for two weeks, if you've got the time, it works. Otherwise I like a good Grinder.
Dremel cutoff tools work ok, but they take forever!!
Happy wrenching
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 03-21-2004, 10:59 PM   #9
DavidM
DavidM's Avatar
PB all the way
David M
Proud Owner of
A 67 C10
Shortfleet 350/350/3.73
DavidM is offline   Reply With Quote
Old 03-21-2004, 11:42 PM   #10
Zeke
Active Member
Best stuff I ever used FREE ALL. Used to get it from local NAPA before they closed. Now I get online. Kinda pricey but better than anything I have ever used, including PB blaster.
http://www.gsasupplyco.com/index.html
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 03-21-2004, 11:51 PM   #11
Lookin4aChevy
PB Buster is the Best.. there is nothing like it. I worked on a rusted bolt for ever used every tool available to me for about three weeks. I'd just work on it when I felt lucky but then I bought PB Blaster and within a couple of minutes I got it unstuck. That suff is amazing.
Lookin4aChevy is offline   Reply With Quote
Old 03-21-2004, 11:53 PM   #12
SS55
I've had great success with Kroil/AeroKroil from Kano Labs.
http://www.kanolabs.com/
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
Old 03-22-2004, 12:11 AM   #13
krazy_texan
krazy_texan's Avatar
i usually spray them in whatever i have and let it soak a little bet and then try it, if that does not work and i am working on something that can withstand it i just tighten the hell out of it until it snaps in half and just buy a new bolt
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 03-22-2004, 12:27 AM   #14
CG
BlahBlahBlah
thanks for the answers everyone...i have never heard of pb blaster, ill give that a shot first.
Old 03-22-2004, 10:04 AM   #15
Blue Beard
Blue Beard's Avatar
Never heard of PB Blaster either.....who sells it...?
I went to a local muffler shop, figuring what they use should be good. But they said I couldn't buy the brand they use.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-22-2004, 10:15 AM   #16
Dean
Dean's Avatar
Kroil is awesome but pricey. That is what we use on Aircraft engines here as well.
Dean is offline   Reply With Quote
Old 03-22-2004, 12:40 PM   #17
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Get a nut splitter.
67Fleetsidedream is offline   Reply With Quote
Old 03-22-2004, 11:33 PM   #18
CG
BlahBlahBlah
i found some at schucks blue beard .... got my nuts soaking in it now :p
Old 03-23-2004, 02:01 AM   #19
angelsairman
Future Owner
angelsairman's Avatar
Mavel Mystery Oil
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 03-24-2004, 04:57 PM   #20
bigskiohio
PB blaster let it soak for afew days and keep spray it coupl times every day. Let it do the work.
bigskiohio is offline   Reply With Quote
Old 03-24-2004, 04:57 PM   #21
bigskiohio
Old 03-25-2004, 09:49 AM   #22
seacrow
seacrow's Avatar
Another vote for PB blaster, I spray it on my old rusty nuts and let them soak overnight. The next day, I have no problems getting them off.
71 GMC Custom. 350, 4bbl., auto. Restored in memory of my grandfather.
2008 Ford F-250 Super Duty CC King Ranch, moonroof, heated captains chairs, 6.4 PowerStroke.
2007 Suzuki Hayabusa, all black
1985 Mustang GT T-top, 5 spd. 54K orig miles.
seacrow is offline   Reply With Quote
