Old 11-20-2016, 04:31 PM   #676
BIGglaSS
BIGglaSS's Avatar
Re: 53 Surburban "Family Truckster"
'burb looks killer laid out. No worries on 220v, just turn it down. You can't pull a long bead with 20 guage anyway. Lots of us use 220v MIG for sheetmetal. I have the new Miller 215 multi. Love it. I mostly TIG sheetmetal now.
BIGglaSS is offline   Reply With Quote
Old 11-21-2016, 05:21 PM   #677
lower50's
lower50's's Avatar
All the welders sound good I have used my Lincoln mig pak 15 240V for 14 years not a single problem. 30A-175A I normally run .035 solid wire but welding sheet metal I run .025 solid wire. Just some more info for you to chew on.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-25-2016, 09:20 PM   #678
youngrodder
youngrodder's Avatar
I decided on a welder and since I have wanted one for soooo long I drove an hr each way to go grab one this morning. I bought a Miller Multimatic 215. It is a slick little compact unit. You can mig,tig and stick weld with this machine. Yes, I even got Miller to throw in a cardboard welding cart for FREE....I will swing by Harbor Freight and pick one up thats not as combustable.
I finished installing my steering. I also finished mounting the column with a 2" drop. Since I had my welder I decided to play with it and fill the hold where the original column stuck through. I will mount my inner fenders too see what changes I need to make to those.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 11-25-2016, 09:31 PM   #679
mongocanfly
mongocanfly's Avatar
That's a nice welder..love the miller welding cart to...I'd change that ground clamp out pronto..get a good ground clamp and you won't regret it..your clamp looks a little different than mine did..mine looked like a clamp for jumper cables...
Old 11-25-2016, 09:47 PM   #680
youngrodder
Thanks..I'm happy with the the ground clamp. It has great grip and large brass contacts. It seems very heavy duty. The mig gun on the other hand looks a little on the cheap side. I would see changing that out at some point, but I'm not getting carried away. This purchase was WAY over due.
Marc
Old 11-25-2016, 11:32 PM   #681
Advanced Design
Advanced Design's Avatar
Hey Marc congrat's on the welder. Looks like you quickly put it to good use!
Advanced Design is offline   Reply With Quote
Old 11-25-2016, 11:39 PM   #682
youngrodder
Yes, I plan to tackle the rear floor structure next...I hope this helps to speed things along.
Marc
Old 11-26-2016, 12:55 AM   #683
reaper71
reaper71's Avatar
Don't even sweat the gun...I have the same one and it works perfect (going on 4 yrs) what size wire did you go with and also make sure you get a separate tank for Argon for the tig
The reason I ask about the wire .023 will lay smoother and you will have less material for cleanup, If I get into heavy wall stuff to weld ill go upto the .030
Mark...
reaper71 is offline   Reply With Quote
Old 11-26-2016, 01:27 AM   #684
lower50's
lower50's's Avatar
Congrats nice looking unit!!!
1951 MG TD
Old 11-26-2016, 01:34 AM   #685
BIGglaSS
BIGglaSS's Avatar
Nice welder! I have the same one. So far, I have only run .023 er70s-2 wire in it. I'm really liking the TIG for sheetmetal. If you haven't bought the TIG kit yet, you can put together better stuff for about the same price.
There is nothing wrong with the ground clamp. It has heavy duty copper jaws with plenty of contact area.
Old 11-26-2016, 10:06 AM   #686
youngrodder
Mark...
Mark
I appreciate all of your tips. I'm using .030. If I drop down to .023 do I need to get .023 tips for my gun? it only came with .030 wire and tips.
Old 11-26-2016, 10:08 AM   #687
youngrodder
Yes, I need to buy the TIG stuff. I have never TIG welded but I do want to learn.
Marc
Old 11-26-2016, 10:37 AM   #688
reaper71
reaper71's Avatar
You can still use the 030 tips it wont really effect the weld at all. I use the same tips.
The ER70-s wire is a great all around wire it welds nice and grinds easy.
When you get ready to get your tig setup let me know, I can give you some websites to go through that I use and the Torch,cups etc to go with
Mark...
Old 11-26-2016, 02:19 PM   #689
mongocanfly
Your stinger should be fine..I've used mine about 20 years..had a little trouble here and there..I just replaced mine with a upgraded heavy duty version and wow...what a difference...like i said..your ground looks better made than mine was..before I changed it out if I did much continuous welding it would get extremely hot and wouldn't clamp tight..I think you'll be fine..I used the tweco clamp on mine now and it works great..
Old 11-26-2016, 10:24 PM   #690
youngrodder
Thanks. I also picked up a welding cart today.
Mark...
Thanks Mark I appreciate the help..
Marc
Old 11-27-2016, 11:12 PM   #691
youngrodder
I got back out in the garage Saturday. I picked up a welding cart since my last one caught on fire....(jk). While Doug is busy shucking peanuts, I'm going to try to catch up...
I have quite a bit of the rear floor structure cut to length. I started to fab up the front section of floor. The plan is a strong structure that will provide support and added structure. I plan to use some type of wood over the top of the structure. If you look closely at the top of the photo you can see where I used some of the old flooring to space out the structure so the same thickness of wood will fit between the flange and support bracing. I'm kicking around a couple different ideas in my head for the wood.
I will use this same 1" x 2" tubing to go over the notch all the way to the rear. This will also provide a nice strong tie in for body mounts.
I tried to take a few pics....the lighting is not the best.
Marc
Old 11-27-2016, 11:49 PM   #692
reaper71
reaper71's Avatar
Looking good Marc
Old 11-28-2016, 12:05 AM   #693
Advanced Design
Yep, I paused my peanut shucking and see you are making good progress. Good idea and direction.
Old 11-28-2016, 12:45 AM   #694
nebdrummer
nebdrummer's Avatar
Soooo cool. Can't wait to see this done. I also wanna see your pickup in person. One of my favorites for sure. I'm glad to see another person with the multimatic. I'm eyeing that one myself. They still have some pretty good deals on them right now.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 11-29-2016, 12:04 AM   #695
youngrodder
Looking good Marc
Thanks Mark
Thanks Doug
Yes, you and me both. I need to figure out the floor and rear tub situation before I pull the body back off and paint the frame. Thanks, you welcome to check out my 48 anytime...Yes, I dig my Multimatic. Rebates good until the end of the year.
Marc
Old 12-04-2016, 11:31 PM   #696
youngrodder
I have been busy working on the floor structure. I added more supports as well as the structure that goes up and over the large notch. I paid close attention to place one of the support structures over the body mounting tabs. I will drill through the support to that I can bolt the body through the floor and structure to the frame like it was from the factory. In one of the pictures you will also see I placed a small piece of the rear floor to get an idea of how it will look.
everything is spot welded at this point. This is a good thing because I had to change around one piece I welded in because I used the wrong measurement...that's what the mock up process is for.
I also added one piece across the notch. I might add another one above the gas tank.
The vision I have for the floor is some type of cool looking wood in the front and rear sections of the floor and a metal notch cover.
Old 12-04-2016, 11:35 PM   #697
youngrodder
Another pic.....The next step will be to trim down the stock inner fenders and raise them up slightly...I saw a guy on Facebook that did something similar with his build. I'm following his lead and putting my spin on it.
Marc
Old 12-05-2016, 11:59 PM   #698
lower50's
lower50's's Avatar
Looking good!! How do you like your welder? Are you accessing your compressor and tanks from underneath or hatch?
1951 MG TD
Old 12-07-2016, 03:27 PM   #699
69CST-V
69CST-V's Avatar
Looking good!!!
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 12-07-2016, 11:08 PM   #700
youngrodder
Lovin the welder...you have no idea. I kick myself for not pulling the trigger sooner. Yes probably. I will have a wood floor that I can remove from above if need be. I can also remove them from the bottom. Not sure the failure rate constitutes the extra work.
Originally Posted by 69CST-V View Post
Looking good!!!
Marc
