Old 12-31-2010, 03:11 PM   #1
ADub
Newb Steering Question
I recently picked up a 69 swb C10. Currently going through it fixing small issues and noticed that the steering centerlink is resting on the engine cradle. The truck sits lower than stock, though I don't think the front is lowered. I think the front springs are just old. Rear has similar old springs, but also has 2" lowering blocks.
Is this normal?
ADub is offline   Reply With Quote
Old 12-31-2010, 08:41 PM   #2
ADub
Re: Newb Steering Question
Tried searching without any luck
69 C10 SWB LY6 T56
70 Chevelle SS 396 4spd
Old 01-01-2011, 02:34 AM   #3
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Centerlink in backwards.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 01-01-2011, 09:42 AM   #4
ADub
Thanks OldGold. When I flip it around, to the inner tie rods still connect on the engine side or should I move them to the front?
69 C10 SWB LY6 T56
Old 01-01-2011, 10:26 AM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
here is a couple of pics for ref.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-01-2011, 10:51 AM   #6
ADub
Thanks. Hopefully get it sorted out today
69 C10 SWB LY6 T56
Old 01-01-2011, 10:52 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Centerlink isn't backwards. The holes for the idler arm, pitman arm, and tie rod ends are tapered. No way to put it in backwards.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-01-2011, 11:07 AM   #8
ADub
I considered that, but don't hold out hope that the P/O had any common sense. I will take a closer look shortly.
69 C10 SWB LY6 T56
Old 01-01-2011, 01:14 PM   #9
ADub
Based on the pics hubscrub posted, its not installed backwards. I also checked the cradle bolts and theres no signs that they are causing the problem
Were there different pitman/idler lengths available based on the year or options? Maybe its got the wrong parts installed?
69 C10 SWB LY6 T56
Old 01-02-2011, 01:47 AM   #10
oldgold70c10
Who's got steelies?
Your right. I was just looking at some pics of ones that were installed backwards, and the tie rods are in front of the center link. His center link looks kinda odd in that it doesn't seem to have the offsets on the ends.
Here is a picture of the centerlink on my own truck. It has enough room to stick a finger between the centerlink and crossmember.
My Truck Page
My Youtube Channel
Old 01-02-2011, 10:30 AM   #11
ADub
My picture doesnt show it well, but my centerlink does have the offsets and its installed in the same orientation as yours.
I looked up all the part numbers for idler arms between the years and they are all the same (67-72). So Im stumped as to why the centerlink is resting on the cradle.
69 C10 SWB LY6 T56
Old 01-02-2011, 11:08 AM   #12
oldgold70c10
Who's got steelies?
Okay. Does it offset up and to the back? Does anything else look odd-maybe a bent or incorrectly installed idler arm?
My Truck Page
My Youtube Channel
Old 01-02-2011, 01:08 PM   #13
ADub
If I understand your questions correctly, yes the centerlink is offset up and towards the rear of the truck relative to the ears that connect to the idler/pitman arm.
The idler and pitman are in decent shape and nothing stands out to me as messed up.
69 C10 SWB LY6 T56
Old 11-19-2016, 12:55 AM   #14
SIXT8LOU
SIXT8LOU's Avatar
hello i know this is a old thread, but did you ever find the problem? Iam having the same problem,,,the link is resting on the cradle...thanks i appreciate it..
68 C/10 short bed
77 C/20 silverado long bed
05 GMC Duramax Crew
SIXT8LOU is offline   Reply With Quote
Old 11-19-2016, 01:34 AM   #15
68bowtie
68bowtie's Avatar
hey there lou. here's a pic of how it should look...
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 11-19-2016, 11:20 AM   #16
SIXT8LOU
SIXT8LOU's Avatar
Attachment 1591494
hey hows it going,,thanks for the reply, i will get a pic later today and post mine, but it is sitting just a bit above yours,,,so its resting on the crossmember, iam pretty sure its correctly installed....lol thanks..
68 C/10 short bed
05 GMC Duramax Crew
Old 11-29-2016, 04:39 PM   #17
ADub
Its been a long time, if I remember correctly that first center link was tweaked and I obtained another center link. Its still close to the xmember, but doesnt touch except when the pitman arm starts coming apart on Hot Rod Power Tour.....
69 C10 SWB LY6 T56
Old 11-30-2016, 11:01 PM   #18
SIXT8LOU
SIXT8LOU's Avatar
thanks ,, i really havent fixed the problem,,,i have it all tightened down and it still is rubbing on crossmember...is it possible that i have it too low,,,i have 2.5 drop spindles with 4inch lowering coils....which i think cud be problem. thanks again...
68 C/10 short bed
05 GMC Duramax Crew
Old 12-01-2016, 11:27 AM   #19
ADub
Your suspension drop is not related to the centerlink clearance at that xmember. The centerlink position relative to the xmember is fixed based on front frame horns and pitman/idler arm. These frames get damaged over time, certainly possible the front frame horns are bent down
69 C10 SWB LY6 T56
