Old 12-03-2016, 09:55 AM   #10
hemi43
hemi43's Avatar
Re: My winter project
Originally Posted by 7D2N View Post
Not sure what to do next. The doors shut nice but rub at the header. Should I shim at A pillar or loosen up the front cowl a bit to see if it will relax some.
7D2N
Adding body shims at the mounts located near the rear of the door should help. Removing shims from the front mounts by the firewall could help also. Before doing any of this, any bolts holding the fenders on should be loosened off. This is a fairly big job because once the front cowl has been moved (rotated) forward, your doors and fenders will have to be realigned for proper gaps.
hemi43 is offline   Reply With Quote
