Old 12-04-2016, 08:02 PM   #1
el_fantasma
el_fantasma's Avatar
cleaning vents on a/c cab
So I cleaned the vents on the driver side easily, lots of junk and no moisture. I went to the passenger side and saw this. I was told that this vent can be opened too but it doesn't seem straight-forward. I pulled on the lever between the vent and the vacuum actuator and the vent flexes a bit but doesn't seem to want to open. My AC doesn't work or I guess I could turn it on and watch it and see how it opens.
Can someone give me some newbie instructions - assume I know nothing.
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 12-04-2016, 08:39 PM   #2
landy
Re: cleaning vents on a/c cab
There's an arm and spring that connects the actuator to the vent door. Remove the arm and spring and you can manually open the vent door.
landy is offline   Reply With Quote
