Old 11-04-2016, 09:38 AM   #1
turp mcspray
turp mcspray's Avatar
WTB tool box lock
Looking for a tool box door lock cylinder, with the pawl and clip.
Thanks!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-10-2016, 11:29 AM   #2
turp mcspray
Re: WTB tool box lock
ttt
Turp Mcspray
Old 11-18-2016, 03:35 PM   #3
turp mcspray
ttt
Turp Mcspray
Old 12-05-2016, 12:04 PM   #4
turp mcspray
ttt
Turp Mcspray
Old 12-05-2016, 01:12 PM   #5
jocko
jocko's Avatar
If anyone knows where to find one, it's Lockdoc - might pm him. Are you hardover on oem? I thought these were available aftermarket.
Old 12-05-2016, 02:19 PM   #6
1969guy
I may be able to help with the pawl and clip but no lock.
Evan
- 1969 C10 LWB fltsd 307 3spd man.steer 3.73 rear orig.white/turquoise poly with drk turquoise int
- 1972 Custom Deluxe10 LWB fltsd 350/TH350 pwr. steer/brks A/C 3.07posi rr orig.med blue with blue cloth trim.
1969guy is offline   Reply With Quote
Old 12-05-2016, 04:11 PM   #7
Ochre Ogre
Ochre Ogre's Avatar
Evan,
Not trying to hijack this thread, but did you ever get any of the Pawls completed? If possible I still need one.
1971 C10 Cheyenne 350/350
Ochre Ogre is offline   Reply With Quote
Old 12-05-2016, 05:55 PM   #8
1969guy
Originally Posted by Ochre Ogre View Post
Evan,
I did, I'll have to get some pics after I get home.
Evan
Old 12-05-2016, 10:57 PM   #9
1969guy
Evan,
Here's a pic. I'm going to heat treat them and paint them. Didn't have time tonight.
Evan
Old 12-06-2016, 08:45 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
I have an idea I'm going to try for a replacement lock cylinder so I will post in the thread so I can find it easily....
LockDoc
Leon
Old 12-06-2016, 10:17 AM   #11
1969guy
LockDoc
Maybe a door lock could be modified? Or use the door lock and cut the hole in a new pawl to fit the door lock. Sounds easy to me if the locks swing the right way.
Evan
Old 12-06-2016, 11:26 AM   #12
Ochre Ogre
Ochre Ogre's Avatar
Peharps LockDock could correct me if I am wrong, but I believe the GM number for the lock is 3987265. It looks correct anyhow. You can search that on ebay and they come up for about 30 bucks. I hope this is the correct one because this is what I purchased. It is from an old Corvette, so it has the added bonus of making your truck much faster
Old 12-06-2016, 01:22 PM   #13
1969guy
Looks about right.
Evan
Old 12-06-2016, 11:39 PM   #14
LockDoc
LockDoc's Avatar
Originally Posted by 1969guy View Post
Looks about right.
I was looking at the mid 50's GM door locks which are basically the same and I have some of those. The only problems I can see are that the key turns 90º in both directions from where the key is inserted (Center) and the key is only removable in the center position. I don't know if the ones sold for the Corvettes rotate 90º without a lock pawl on them or if they rotate 360º. I think the original tool box lock is designed so that the key is removable in the locked and unlocked positions. You can't do that with the Corvette or '50's GM door locks.... I was going to check and see if they could be modified.
LockDoc
Leon
Old 12-07-2016, 02:23 PM   #15
Ochre Ogre
Ochre Ogre's Avatar
Thanks LockDoc, I will try and check when I get home. It seems to me that it only rotates 90 degrees, but not sure if the key comes out or not in both positions.
Old 12-07-2016, 03:19 PM   #16
turp mcspray
Interested!
Turp Mcspray
Old 12-09-2016, 12:29 PM   #17
Ochre Ogre
Ochre Ogre's Avatar
I checked the lock cylinder and it just turns 90 deg and you can remove the key in both positions. pictures attached
Old 12-10-2016, 12:55 AM   #18
LockDoc
LockDoc's Avatar
That should be correct then. I'm not sure how it can be used for a Corvette door lock. Maybe the Corvette door locks work different than the normal car locks.... Let us know if it turns the right way to lock & unlock when you get it installed.
LockDoc
Leon
Old 12-10-2016, 12:37 PM   #19
John H.
John H.'s Avatar
I think I have an NOS set I bought from Locdoc.
Let me look. Not sure what it is worth.
Just the lock set
John H. is offline   Reply With Quote
Old 12-10-2016, 08:37 PM   #20
John H.
John H.'s Avatar
I am keeping my NOS set. I do have a lock without key or the paw but will have the holding clip if I can remove without breaking. It is the one without the key. 67Kid on this board may have the key since I received the door from him.
Old 12-12-2016, 12:14 PM   #21
turp mcspray
John H, Thanks for the offer. I already ordered a new lock cylinder.
Turp Mcspray
