![]() Join Date: Mar 2012
brake line routing question
69 gmc 3/4ton 4x4, what is the correct brake line routing from master cyl back to rear axle? there is a bracket on the pass side frame rail for the rear hose. im thinking it ran across the front pass then back? i dont remember,also i think the correct lines are 1/4'' thanx, paul
Re: brake line routing question
It runs across the back of the front crossmember to inside the right frame rail.
Yup it's all coming together now. This rig was "rigged"when I got it. Lol. Now I have to toss a coin on pre Bent or do the lines myself.
![]() ![]() Join Date: Jan 2015
And the line is 1/4 inch if you do it yourself try the ni-cop line it is nice to work with and won't ever rust very easy to bend and form
FWIW, I just did lines on a 71 GMC 3/4 ton 4x4. I use Inline Tube lines. The front lines fit OK, they were not exact replications of the OE lines (may or may not matter to you) The rear brake lines form the front of the pass frame rail back were so far off I ended up making my own. Especially the rear axle lines - no possible way to make them fit. But, the lines are beautifully made even if they don't fit!
we will see, havent decided.
New lines from the auto stores are cheap.
My opinion is even if you buy a bender and a flare tool and lines you can still come in under the price of inline's prices. Of course not greatest quality tools but usefull for a few jobs. Nicop lines are nice. I don't have much experience with it but the few times I have used it I kinked some and had some flares crack. I thought that was strange since it seems softer. Maybe it was just me. Also I haven't seen the difference of the longengevity of nicop compared too the steel lines. My opinion is the steel lines are ok but certainly don't last like oe lines. One problem with making your own lines is the fittings. I try not too use the fittings that comes on the lines"they are cheap". I save all good shape oe fittings and clean them up for reuse Takes a lil' longer but way better material and they will be correct. I only do this on my personal rides as time is $. Obviously stainless is the way too go but very pricey. I would be highly upset if I paid for their stainless kit and they didn't fit correctly. I actually enjoy running new lines making nice bends and fitting everything just right is a challenge I like.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
the only thing that i need to figure out is where does the front "tee" go. somewhere on drivers side.
what i did keep from the front had the connector marked x in pics. never seen one. 3753459 is what my book says for my app. this book doesnt show that #. im sure they changed #'s . the book here says my app uses "y" in pic. im confused
#10 | |
this pic is for a 71 with disc brakes, I have a 70 3/4 ton with drum brakes, it's routing is slightly different. I can get pics of the tee if you want. |
if you can, i didnt have much to work with when i got this truck, id like a pic off the mc down to fronts. no hurry, thanx bw
If you need something more detailed / specific let me know
that is perfect b.w!!!! thanx so much!!!!
No prob. You gotta love this forum! So much info / knowledge & help.
#15 |
you aint kiddin!
