![]() Join Date: Jul 2014
Re: Best aftermarket/rebuilt manual tilt steering column? Also, radiator support patc
I just replaced my core support. Ordered a new one from LMC. When it arrived, it wasn't the right one... the center braces with the angled part half way up for mounting the grill, wasn't there... just straight braces. No holes for the right and left grill supports next to the headlights.
So, being up against very tight time constraints and a sandblaster and powdercoater waiting for all the engine bay sheetmetal, I looked closely at the corner profiles of the "new" replacement. Careful measurements indicated that it should work to cut the corner off the new one and weld it to the OEM. Can't tell after powdercoating. Ended up with a $150 patch because I couldn't find one online. Some enterprising individual capable of bending the sheetmetal, can make some coin bending patches.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
| Bookmarks |
| Tags |
| manual, radiator support, steering, tilt |
