Closed Thread
Old 12-07-2016, 01:58 PM   #4701
hamjet
hamjet's Avatar
Re: What did you do to your truck today? Chapter II
Very nice!!!
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 12-07-2016, 02:09 PM   #4702
toolboxchev
Originally Posted by matthamby View Post
installed my first "modern" accessory!
Nice, Dig it, Let it Roar!
I let mine get covered in frost today, I will look forward to driving it again 46 years later, again, today.
Farm truck tough!
toolboxchev is offline
Old 12-07-2016, 02:16 PM   #4703
matthamby
Originally Posted by colgad View Post
Just got my 6.0 swap running and driving! Took a little longer than I planned but you run into stuff like the hose sizes to the radiator I used an 1.5 to 1.25 adapter and PS hose compatibility was a small issue too but it all works out. So nice just to turn the key and it runs instantly.
Wow! that does look nice!
Are you using the factory A/C from the 6.0 or is that Vintage Air?
How does all of that tie into the cab? It looks like the factory fan box isn't there, can't really tell from the angles of the pics.
What hydroboost brake system is that - did it come from Wilwood?
matthamby is offline
Old 12-07-2016, 02:43 PM   #4704
mild68
mild68's Avatar
colgad, nice looking set up.
mild68 is offline
Old 12-07-2016, 04:51 PM   #4705
colgad
colgad's Avatar
Vintage AC was in the C10 with the 350 I got the bracket for the 6.0 off of ebay.
The hydroboost is out of an Astro with a Willwood master.
Stock 71-72 front disks and Caddy rear disks. I have two Spal two speed fans on an ebay aluminum radiator. I have the computer control Fan1 and Fan2 on low speed and a seperate sensor controls the high speed on Fan1 and Fan2
I used LT1swap.com instructions to modify the old harness and sent him the cpu to flash.
Thanks for the nice comments.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 12-07-2016, 04:55 PM   #4706
colgad
colgad's Avatar
Originally Posted by flashed View Post
Wow ,that looks nice .
Thanks, I credit the ebay aluminum intake, it sure beats the stock black plastic one for looks.
colgad is offline
Old 12-07-2016, 04:56 PM   #4707
colgad
colgad's Avatar
colgad is offline
Old 12-07-2016, 04:59 PM   #4708
matthamby
This is why I love this thread, it has so many good ideas and great information - especially while planning the resto-mod!
Old 12-07-2016, 05:01 PM   #4709
colgad
colgad's Avatar
I used junk yard 2010 Camaro exhaust manifolds that I cut the flanges off that held the heat shield and flap wheeled them till they were sort of smooth and then had them coated. Total cost including the $150 for coating was $235. They fit better than the 350 sanderson headers did for sure.
colgad is offline
Old 12-07-2016, 05:06 PM   #4710
colgad
colgad's Avatar
I know, there is nothing else like it. I got so many great idea's when I was building my C50's.
colgad is offline
Old 12-07-2016, 08:21 PM   #4711
Slowboat
you are correct! my plans are to eventually remove the ash tray also - basically all of the items that are recessed into the dash will be filled, this will allow for installation of some components I want in my dash and they won't look like they were just Jerry-rigged in there.
Can you give a link to the one you used? I ordered one from Amazon, but it is too big to fit in the stock lighter hole
Slowboat is offline
Old 12-07-2016, 09:45 PM   #4712
colgad
colgad's Avatar
You do have a nice stepside but the Chevelle WOW! That blue is really something.
colgad is offline
Old 12-08-2016, 09:28 AM   #4713
matthamby
Mine was too large also, I had to use a "step bit", it's used to cut small holes into larger ones for conduit into electrical panels (I have used them many times) they are about $35 at Lowe's Home Improvement, make sure to get the one that is up to 1-1/8", at least that's what mine was. See if you have an electrician friend, they may have one you could use. Don't try holding a hole saw in place - it won't turn out well (for the truck or you, I have seen people try it). I have several vehicles that I want to add one of the sockets to, so the $35 wasn't a bad deal.
I took a round file to remove the barbs that remained from the bit. It was a really tight fit so it doesn't move around inside the hole, I just got it in there, I started to hook up the wires, but when I started looking at the wiring, it was quite obvious that whoever installed the radio (non factory, i don't think a dealer did it either), there was a nest of wires, a lot of them were cut and hanging loose, so I need to chase them out and see what goes where and remove wires that are not necessary. Nothing can ever be easy!
You may be able to use a small grinding wheel on a Dremel tool to make the hole larger, mark the hole needed then cut, this would also allow you to leave the sides flat so the power adapter is "keyed" into the hole.
Thanks guys!
Old 12-09-2016, 12:03 AM   #4714
mild68
mild68's Avatar
mild68 is offline
Old 12-09-2016, 11:06 AM   #4715
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Looking good there ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 12-09-2016, 11:17 AM   #4716
74baggedbug
Started scraping all the epoxy coating off the wood, this past weekend .. I stained it and waiting on the epoxy coating to show up
74baggedbug is offline
Old 12-09-2016, 12:16 PM   #4717
VWNate1
VWNate1's Avatar
Question Re: What did you do to your truck today? Chapter II
RE: Bed Wood :
Is that some sort of one piece bed ? .
My '69 has the usual planks and metal strips .
This looks like the basis for a beautiful custom (non work) bed floor .
-Nate
Geezer
VWNate1 is offline
Old 12-09-2016, 10:44 PM   #4718
CST10
CST10's Avatar
Red face Re: What did you do to your truck today? Chapter II
That's awesome. I love it.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 12-09-2016, 11:19 PM   #4719
vintagefarmer
vintagefarmer's Avatar
I went out and spun mine over. Hasnt ran for awhile since the brakes went out. Decided it needed to run for a little bit and shake the mice out of it. Fired right up in the cold weather and let her get up to temp before shutting it down again.
vintagefarmer is offline
Old 12-09-2016, 11:40 PM   #4720
mild68
mild68's Avatar
Of course , broken exhaust bolts.
Last one is just below the surface. I can't get a weld to hold it. ERRR
I drilled and tried easy out, gave up afraid it was going to break.
mild68 is offline
Old 12-10-2016, 06:15 AM   #4721
74baggedbug
Originally Posted by VWNate1 View Post
RE: Bed Wood :
Yes it lays over the top of my metal floor, if I need to haul something I can remove the wood floor in less than 5min... thinking I may have some pinstriping done on it before we lay the epoxy over it again
Old 12-10-2016, 06:40 AM   #4722
hamjet
hamjet's Avatar
the heat from welding the nuts on is whats helping break the others loose. find something to fit kind of tight into the hole of the drilled stud, heat it with a torch to transfer the heat throughout the bolt, remove the ( something), and try the easy-out while its hot...
Thanks, Joe..
hamjet is offline
Old 12-10-2016, 07:03 AM   #4723
mild68
mild68's Avatar
Thanks, I'll give that a try.
mild68 is offline
Old 12-10-2016, 09:38 PM   #4724
mild68
mild68's Avatar
I gave it another try today. No luck. I'm a little leary of breaking an extractor.
I dug up some I've had for quite a while. You can tell by the price. lol
Did get bushings pressed in and arms painted.
Bracket and power steering pump painted
mild68 is offline
Old 12-11-2016, 09:36 PM   #4725
mild68
mild68's Avatar
Put a little more time today detailing parts.
Got the power steering pump pulley back on.
Disassembled and detailed alternator.
mild68 is offline
Closed Thread
