12-06-2016, 10:44 PM | #1 |
T56 & Slave Cylinder Fitment Help Needed
Bought a new GM Performace Parts T56 and install kit. The slave cylinder disconnect does not clear the transmission out of the box, is GM just this sloppy? One side of me says to pull out the die grinder, the other side of me says maybe I am doing something wrong?
12-07-2016, 01:44 AM | #2 |
Senior Moment
Re: T56 & Slave Cylinder Fitment Help Needed
Wow Mine pushed right it no problem
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
12-08-2016, 05:57 PM | #3 |
use a grinder
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
12-08-2016, 10:26 PM | #4 |
Yep, spent 5 minutes with a flat file, cleaned it up and it fit just fine. Doesn't line up with the bell housing but it works:
The upper hole for the bleeder looks like it was milled correct. Guess someone went to lunch and forgot to finish when they got back that day. |
12-09-2016, 08:17 PM | #5 |
Ah the ole Friday build
