Old 05-30-2016, 09:07 AM   #1
jr1000yarder
69 washer bottle location
Any have a picture of where the windshield washer bottle goes on a BBC 69?
I believe we have the original bracket just not too sure.
Thanks, Rich
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 05-30-2016, 10:11 PM   #2
jr1000yarder
Re: 69 washer bottle location
Anyone?!??
IT IS WHAT IT IS
Old 05-30-2016, 10:26 PM   #3
FirstOwner69
FirstOwner69's Avatar
I don't know about big block trucks, but my 69 (Dec., 1968 build) with a 350 has always had it on the core support. Some pics I've seen of 69s show it on the left fender. Do the big block trucks have the power steering reservoir on the fender?
Here are the 2 bracket styles I've seen. The one on the right is the core support style.
FirstOwner69 is offline   Reply With Quote
Old 06-01-2016, 11:17 AM   #4
Tdrcreyn4
Tdrcreyn4's Avatar
The bracket on the right side of the picture came on trucks ordered with the auxiliary battery and mounts to the right fender in front of the main battery. First owner 69 is right about the power steering. If you have a big block equipped power steering truck the auxiliary fill reservoir bolts to the left fender. Really depends on what options you have to answer your question fully.
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 06-01-2016, 12:48 PM   #5
jr1000yarder
yes my ps fluid reservoir is mounted to the drivers fender...
IT IS WHAT IT IS
Old 06-01-2016, 01:37 PM   #6
FirstOwner69
Just to clarify what I said above... mine (small block) has been on the core support since the truck was new using the bracket with the extension on the back. I THINK that's where they were on the small block trucks from 1967 until sometime in the 1969 model year when they were moved to the left fender location. I was not aware that bracket was also used with the auxiliary battery option. I posted the picture because the OP mentioned he had a bracket and figured it might help I.D. the location.
The OP may want to look at the right fender for mounting holes.
Old 06-01-2016, 06:22 PM   #7
Ringo934
Ringo934's Avatar
I have a 1969 GMC with a 350. Mine is mounted on the driver's side above the inner fender.
1969 GMC C/1500 LWB Wideside
355 SBC/TH400/3.73 posi-traction
Daily Driver.
Carburetors, because I don't care to consort with that of the robot race.
Ringo934 is offline   Reply With Quote
Old 06-01-2016, 09:03 PM   #8
jr1000yarder
That's where my ps is
IT IS WHAT IT IS
Old 06-01-2016, 09:12 PM   #9
Ringo934
Ringo934's Avatar
Looks like there is plenty of room left for a windshield washer fluid reservoir.
Daily Driver.
Old 06-01-2016, 09:42 PM   #10
FirstOwner69
Here's a picture showing the bracket location on my 69. Do you have a couple holes in the core support above the voltage regulator, one above the other, maybe 2 inches apart? I so, do they appear to have been "threaded" by sheet metal screws? Have you determined which bracket you have?
EDIT: Added 2nd picture from the front showing the holes in the core support.
Old 06-02-2016, 08:54 AM   #11
Aus69c20
Aus69c20's Avatar
My 69's a factory bb and it has the washer bottle in the same location as firstowner69s picture.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 06-02-2016, 10:54 AM   #12
jr1000yarder
SWEET!!!!!!! I didn't look there. I will look tonight. I'll post a pic of my bracket also.
THANKS!!!!!!!!!!!
IT IS WHAT IT IS
Old 06-02-2016, 01:14 PM   #13
rally
My 69 350 has the bottle in the same spot as Ringo's.
rally is offline   Reply With Quote
Old 06-02-2016, 07:32 PM   #14
jr1000yarder
Well...I have the 2 holes like FirstOwner69 posted and..I think my bracket is CORRECT! !! THANKS EVERYONE! !
Are the washer bottles on ebay the right ones?? They say oem NOS for our trucks..any suggestions on "guts" to make it all work?
IT IS WHAT IT IS
Old 12-08-2016, 10:24 AM   #15
gmc 2500 4x4
subscribed
gmc 2500 4x4 is offline   Reply With Quote
Old 12-08-2016, 10:54 AM   #16
LongBox
Here's what's on my truck. I have no other info.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 12-08-2016, 11:03 AM   #17
gmc 2500 4x4
i have that one also, 73-? 71-72 neck/cap different
Old 12-10-2016, 10:21 AM   #18
Tdrcreyn4
Tdrcreyn4's Avatar
Here are scans from the Factory Assembly Instruction Manual. The first picture shows the standard location and bracket for the washer bottle located on the driver's side front fender. Pictures 2 and 3 show the location of the washer bottle on the passenger's side front fender just in front of the battery. The bracket for this application was different and was used when the auxillary battery was ordered. Hope this helps.
Old 12-10-2016, 11:02 AM   #19
gmc 2500 4x4
i didnt think bout lookin in my book. im an idiot lol thank you!
